[mpich-discuss] build cluster
Gustavo Correa gus at ldeo.columbia.edu
Fri Nov 26 14:53:54 CST 2010
Hi
If you are just starting with clusters,
it may be easier to install Rocks:
http://www.rocksclusters.org/wordpress/
It is based in CentOS, not Ubuntu, but it will take care of
many cluster details for you, saving a lot of time and effort.
Install the basic "rolls" and chose from Torque *or* SGE job queue managers (not both).
Then install your own MPICH2 in /share/apps in the head node/frontend node.
You'll be up and running faster.
Rocks is free, has a decent User Guide,
which you should read before you start installation, additional
documentation, and mailing list support.
My two cents,
Gus Correa
On Nov 26, 2010, at 6:49 AM, ibrahim gad wrote:
> <--static--bamboo_tc.jpg>
> hi
>  I  would be thankful if you help me
>  1- I want to build small cluster ( i have 3 pc core2duo -ubuntu 9.10)
> 2- I want to run mpi program
> i need to make all processors to write on the same file(master)
> thank you for your help
> ibrahim gad
> <--static--bamboo_bc.jpg>
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
