[mpich-discuss] Urgent help needed for Mpich1.2.7p1 installation
Reuti
reuti at staff.uni-marburg.de
Mon Nov 22 03:18:42 CST 2010
Am 22.11.2010 um 03:59 schrieb Shaandar Nyamtulga:
> I am trying to create Beywolf cluster for 2 computers.(One is desktop, one is laptop, Both has Ubuntu OS)
> I am following one guy's instructions in the following link.The guy stated that he could not do it for mpich2, that is why I am sticking with mpich1.
MPICH1 is no longer maintained, so I wouldn't be surprised when at one point it's no longer working out of the box. Maybe the author of the instructions hassled with the mpd startup and mpdboot at that time, which was used in former versions of MPICH2. Just use MPICH2 in version 1.3.1 and it should work with the default Hydra startup manager similar to the old MPICH(1). As an alternative you can also try Open MPI.
-- Reuti
NB: there is also a bug in the page you listed: to use a notation like "node1:2" it was necessary to compile MPICH(1) with "-comm=shared".
> http://www.ceglug.org/index.php/cluster/3-createcluster?start=1
> But I receive the following error from make.Actually it is end of the message.
> ** Testing if C application can use both automatic and manual logging together
> /home/mpiuser/mpich-1.2.7p1/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -I/home/mpiuser/mpich-1.2.7p1/include -c cpilog.c
> /home/mpiuser/mpich-1.2.7p1/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -o cpilog cpilog.o -L/home/mpiuser/mpich-1.2.7p1/lib -llmpe -lmpe -lm
> ** C application can use both automatic and manual logging together
> ./sbin/mpeinstall: 493: ./sbin/install-package: not found
> Installed MPE in /home/mpiuser/mpich-1.2.7p1
> /home/mpiuser/mpich-1.2.7p1/sbin/mpeuninstall may be used to remove the installation
> Finished making MPE Profiling Libraries
> make --no-print-directory mpi-utils
> gcc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -c /home/mpiuser/mpich-1.2.7p1/mpid/server/serv_p4.c -I./ -o serv_p4.o
> /home/mpiuser/mpich-1.2.7p1/mpid/server/serv_p4.c:204: error: conflicting types for ‘getline’
> /usr/include/stdio.h:671: note: previous declaration of ‘getline’ was here
> /home/mpiuser/mpich-1.2.7p1/mpid/server/serv_p4.c: In function ‘sendline’:
> /home/mpiuser/mpich-1.2.7p1/mpid/server/serv_p4.c:1295: warning: format not a string literal and no format arguments
> /home/mpiuser/mpich-1.2.7p1/mpid/server/serv_p4.c: At top level:
> /home/mpiuser/mpich-1.2.7p1/mpid/server/serv_p4.c:1306: error: conflicting types for ‘getline’
> /home/mpiuser/mpich-1.2.7p1/mpid/server/serv_p4.c: In function ‘getline’:
> /home/mpiuser/mpich-1.2.7p1/mpid/server/serv_p4.c:1309: error: argument ‘str’ doesn’t match prototype
> /usr/include/stdio.h:671: error: prototype declaration
> /home/mpiuser/mpich-1.2.7p1/mpid/server/serv_p4.c:1309: error: argument ‘len’ doesn’t match prototype
> /home/mpiuser/mpich-1.2.7p1/mpid/server/serv_p4.c:1309: error: number of arguments doesn’t match prototype
> /home/mpiuser/mpich-1.2.7p1/mpid/server/serv_p4.c: In function ‘failure’:
> /home/mpiuser/mpich-1.2.7p1/mpid/server/serv_p4.c:1348: warning: format not a string literal and no format arguments
> make[2]: *** [serv_p4.o] Error 1
> bin/mpicc -o /home/mpiuser/mpich-1.2.7p1/bin/mpichversion /home/mpiuser/mpich-1.2.7p1/util/mpichversion.c
> /home/mpiuser/mpich-1.2.7p1/util/mpichversion.c: In function ‘main’:
> /home/mpiuser/mpich-1.2.7p1/util/mpichversion.c:67: warning: incompatible implicit declaration of built-in function ‘exit’
> rm -f /home/mpiuser/mpich-1.2.7p1/bin/mpireconfig.dat
> creating util/mympiinstall
> Completed build of MPI. Check the output for errors Also try executing 'make
> testing' in examples/test (This relies on mpirun, which currently works for
> many but not all systems. For workstation networks, mpirun requires that you
> first setup a "machines" file listing the machines available; this is covered
> in the installation manual.)
> Send bugs and comments to mpi-bugs at mcs.anl.gov
> Bugs and comments in the C++ support should be sent to mpi2cpp-devel at osl.iu.edu
> Bugs and comments in the MPI-IO support should be sent to
> romio-maint at mcs.anl.gov
> With any bug report, please send
> The version of MPICH (e.g., 1.2.7)
> The output of running your program with the -mpiversion argument
> (e.g., mpirun -np 1 a.out -mpiversion)
> The output of
> uname -a
> for your system. If you are on an SGI system, also
> hinv
> If the problem is with a script like configure or mpirun, run the script with
> the -echo argument (e.g., mpirun -echo -np 4 a.out )
> If you are using a network of workstations, also send the output of
> bin/tstmachines.
> Please help me.
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
