[mpich-discuss] issue setting process-core mapping with hydra
Pavan Balaji balaji at mcs.anl.gov
Wed Nov 10 19:37:45 CST 2010
On 11/10/2010 12:14 PM, sreeram potluri wrote:
> The error output I had observed was because debug mode was enabled
> inside hwloc. It appears that the hwloc debug mode is enabled by default
> when we do an svn checkout. This does not happen if we do an export
> instead. I believe you did an export and hence did not see the debug
> output.
Ugh. That's gross. I don't know why hwloc does that. I've fixed it in
the copy within MPICH2:
https://trac.mcs.anl.gov/projects/mpich2/changeset/7435
  -- Pavan
Pavan Balaji
http://www.mcs.anl.gov/~balaji
