[mpich-discuss] issue setting process-core mapping with hydra
sreeram potluri potluri at cse.ohio-state.edu
Wed Nov 10 07:49:32 CST 2010
Pavan,
While configuring MPICH2, I had used a default configure, if this
information is helpful.
Sreeram Potluri
On Wed, Nov 10, 2010 at 8:42 AM, sreeram potluri <potluri at cse.ohio-state.edu
> wrote:
> Pavan,
> Attached is some information about the machines I am trying this on.
> We have SLURM (2.1.11) installed on this cluster. Do you know of any
> interactions that this could have?
> Thank you
> Sreeram Potluri
> On Wed, Nov 10, 2010 at 8:29 AM, Pavan Balaji <balaji at mcs.anl.gov> wrote:
>> Sreeram,
>> I'm not able to reproduce this on any of our platforms with trunk, so it
>> looks like it's something specific to your hardware. What system is this
>> (OS, /proc/cpuinfo, whatever else might be relevant)?
>>  -- Pavan
>> On 11/09/2010 05:23 PM, sreeram potluri wrote:
>>> Hi,
>>> I am observing an issue when specifying process-core binding using
>>> mpiexex.hydra. I am using the trunk version of MPICH2. When I use the
>>> following command
>>> ../bin/mpiexec.hydra -binding user:0,1 -n 2 -f hosts ./hellow
>>> it prints out the following error. However, the tests complete fine. I
>>> assume it uses some preset binding.
>>> Restrict topology cpusets to existing PU and NODE objects
>>> Propagate offline and disallowed cpus down and up
>>> This error does not happen with the version of hydra available here :
>>> http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/1.3/hydra-1.3.tar.gz
>>> My hosts file is as follows:
>>> [potluri at wci-login examples]$ cat hosts
>>> wci37
>>> wci37
>>> Please suggest if I am missing something here. Thanks in advance.
>>> Regards
>>> Sreeram Potluri
>>> _______________________________________________
>>> mpich-discuss mailing list
>>> mpich-discuss at mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>> Pavan Balaji
>> http://www.mcs.anl.gov/~balaji
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20101110/0a12e49f/attachment.htm>
