[mpich-discuss] cygwin & mingw64 & windows 7 (64bits)
Jayesh Krishna
jayesh at mcs.anl.gov
Tue Nov 9 10:49:33 CST 2010
It looks like mingw gcc doesn't play nice with windows libraries (Cygwin gcc - atleast the newer versions - works well with windows libs). I verified that creating an MPICH2 wrapper library works with C programs compiled with mingw.
I am in the process of modifying MPICH2 to support gfortran (Currently we only support g77). Follow the ticket - https://trac.mcs.anl.gov/projects/mpich2/ticket/278#comment:9 - on this effort.
I should be able to provide you a custom library that you can use in a day or two.
Jayesh
----- Original Message -----
From: Jean-Michel Beuken <Jean-Michel.beuken at uclouvain.be>
Sent: Tue, 09 Nov 2010 08:42:43 -0600 (CST)
Subject: Re: [mpich-discuss] cygwin & mingw64 & windows 7 (64bits)
Hello,
On 08/11/2010 22:32, Jayesh Krishna wrote:
> Hi,
> From the error code it looks like access violation. Can you try running the executable from a mingw bash prompt ?
> I will also try installing mingw 64-bit at the lab and let you know the results.
for info :
I install TDM-GCC (64bits) and I have the sames symptomes but the gdb works in ssh/bash environement :
gfortran -g -IC:\\mpich2\\include -c pi3f90.f90 -fno-range-check -fsecond-underscore
gfortran -g -o pi3f90 pi3f90.o -LC:\\mpich2\\lib -lfmpich2g -lmpi
$ gdb pi3f90.exe
GNU gdb (GDB) 7.1
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This GDB was configured as "x86_64-w64-mingw32".
Reading symbols from C:\Users\buildbot\Desktop\WorkSpace/pi3f90.exe...done.
(gdb) run
Starting program: C:\Users\buildbot\Desktop\WorkSpace/pi3f90.exe
[New Thread 1984.0xa30]
Program received signal SIGSEGV, Segmentation fault.
0x0000000000401960 in mpi_init__ ()
(gdb) where
#0 0x0000000000401960 in mpi_init__ ()
#1 0x00000000004015be in MAIN__ () at pi3f90.f90:37
$ gdb --args c:\\mpich2\\bin\\mpiexec.exe -n 4 -exitcodes pi3f90.exe
GNU gdb (GDB) 7.1
Reading symbols from c:\mpich2\bin\mpiexec.exe...(no debugging symbols found)...done.
(gdb) run
Starting program: c:\mpich2\bin\mpiexec.exe -n 4 -exitcodes pi3f90.exe
[New Thread 2608.0xba8]
[New Thread 2608.0x78]
rank: node: exit code
0: woopy.pcpm.ucl.ac.be: -1073741515
1: woopy.pcpm.ucl.ac.be: -1073741515
2: woopy.pcpm.ucl.ac.be: -1073741515
3: woopy.pcpm.ucl.ac.be: -1073741515
[New Thread 2608.0xd08]
Program exited with code 030000000465.
(gdb) where
(gdb) No stack.
regards
jmb
mpich-discuss mailing list
