[mpich-discuss] *** glibc detected *** mpiexec: munmap_chunk(): invalid pointer: 0x00007fff1d578184 ***
Jeff Hammond jhammond at mcs.anl.gov
Sat Nov 6 09:11:35 CDT 2010
Sorry for not including this last time, but valgrind seems to indicate
the problem is in Hydra.
Jeff
==1525== Invalid free() / delete / delete[]
==1525==    at 0x4C243AF: free (in
/usr/lib64/valgrind/amd64-linux/vgpreload_memcheck.so)
==1525==    by 0x421983: HYDT_bsci_finalize (bsci_finalize.c:21)
==1525==    by 0x40A07E: HYD_pmci_finalize (pmiserv_pmci.c:371)
==1525==    by 0x40537E: main (mpiexec.c:327)
==1525==  Address 0x7ff000149 is on thread 1's stack
==1525==
==1525== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 2 from 1)
==1525== malloc/free: in use at exit: 16,396 bytes in 3 blocks.
==1525== malloc/free: 1,698 allocs, 1,696 frees, 118,394 bytes allocated.
==1525== For counts of detected errors, rerun with: -v
==1525== searching for pointers to 3 not-freed blocks.
==1525== checked 184,080 bytes.
==1525==
==1525==
==1525== 6 bytes in 1 blocks are still reachable in loss record 1 of 3
==1525==    at 0x4C256AE: malloc (in
==1525==    by 0x5EB1261: strdup (in /lib64/libc-2.9.so)
==1525==    by 0x41EA50: HYDT_bind_init (bind.c:44)
==1525==    by 0x4096BE: HYD_pmci_launch_procs (pmiserv_pmci.c:293)
==1525==    by 0x4050B0: main (mpiexec.c:289)
==1525==
==1525==
==1525== 6 bytes in 1 blocks are definitely lost in loss record 2 of 3
==1525==    by 0x41EFFB: HYDT_bind_init (bind.c:40)
==1525==
==1525==
==1525== 16,384 bytes in 1 blocks are still reachable in loss record 3 of 3
==1525==    by 0x41EB08: HYDT_bind_init (bind.c:53)
==1525==
==1525== LEAK SUMMARY:
==1525==    definitely lost: 6 bytes in 1 blocks.
==1525==      possibly lost: 0 bytes in 0 blocks.
==1525==    still reachable: 16,390 bytes in 2 blocks.
==1525==         suppressed: 0 bytes in 0 blocks.
On Sat, Nov 6, 2010 at 9:08 AM, Jeff Hammond <jhammond at mcs.anl.gov> wrote:
> Yep, still happening when I use MPICH2-1.3 pulled via SVN yesterday
> and compiled with GCC 4.6.  The test that fails is extremely simple.
> Jeff
> jeff at localhost:~/eclipse/a1/trunk/benchmarks/mpi> cat MPI_simple.c
> #include <stdio.h>
> #include <mpi.h>
> int main(int argc, char **argv)
>    int provided;
>    int rank, size;
>    MPI_Init_thread(&argc, &argv, MPI_THREAD_SINGLE, &provided);
>    MPI_Comm_rank(MPI_COMM_WORLD, &rank);
>    MPI_Comm_size(MPI_COMM_WORLD, &size);
>    MPI_Barrier(MPI_COMM_WORLD);
>    printf("before MPI_Finalize\n"); fflush(stdout);
>    MPI_Finalize();
>    printf("after MPI_Finalize\n"); fflush(stdout);
>    return(0);
> /software/mpich/mpich2-1.3-gnu46-build/bin/mpiexec -n 2 MPI_simple.x
> before MPI_Finalize
> after MPI_Finalize
> before MPI_Finalize
> after MPI_Finalize
> /software/mpich/mpich2-1.3-gnu46-build/bin/mpiexec: munmap_chunk():
> invalid pointer: 0x00007fffd654016b ***
> ======= Backtrace: =========
> /lib64/libc.so.6[0x7f1cca7040c8]
> /software/mpich/mpich2-1.3-gnu46-build/bin/mpiexec[0x421984]
> /software/mpich/mpich2-1.3-gnu46-build/bin/mpiexec[0x40a07f]
> /software/mpich/mpich2-1.3-gnu46-build/bin/mpiexec[0x40537f]
> /lib64/libc.so.6(__libc_start_main+0xe6)[0x7f1cca6ae586]
> /software/mpich/mpich2-1.3-gnu46-build/bin/mpiexec[0x404359]
> ======= Memory map: ========
> 00400000-00449000 r-xp 00000000 08:03 312441
>  /software/mpich/mpich2-1.3-gnu46-build/bin/mpiexec.hydra
> 00648000-00649000 r--p 00048000 08:03 312441
> 00649000-0064b000 rw-p 00049000 08:03 312441
> 0064b000-00672000 rw-p 0064b000 00:00 0                                  [heap]
> 7f1cca479000-7f1cca48e000 r-xp 00000000 08:02 1417264
>  /lib64/libgcc_s.so.1
> 7f1cca48e000-7f1cca68e000 ---p 00015000 08:02 1417264
> 7f1cca68e000-7f1cca68f000 r--p 00015000 08:02 1417264
> 7f1cca68f000-7f1cca690000 rw-p 00016000 08:02 1417264
> 7f1cca690000-7f1cca7df000 r-xp 00000000 08:02 1417222
>  /lib64/libc-2.9.so
> 7f1cca7df000-7f1cca9df000 ---p 0014f000 08:02 1417222
>  /lib64/libc-2.9.so
> 7f1cca9df000-7f1cca9e3000 r--p 0014f000 08:02 1417222
>  /lib64/libc-2.9.so
> 7f1cca9e3000-7f1cca9e4000 rw-p 00153000 08:02 1417222
>  /lib64/libc-2.9.so
> 7f1cca9e4000-7f1cca9e9000 rw-p 7f1cca9e4000 00:00 0
> 7f1cca9e9000-7f1cca9ff000 r-xp 00000000 08:02 1417248
>  /lib64/libpthread-2.9.so
> 7f1cca9ff000-7f1ccabff000 ---p 00016000 08:02 1417248
> 7f1ccabff000-7f1ccac00000 r--p 00016000 08:02 1417248
> 7f1ccac00000-7f1ccac01000 rw-p 00017000 08:02 1417248
> 7f1ccac01000-7f1ccac05000 rw-p 7f1ccac01000 00:00 0
> 7f1ccac05000-7f1ccac0d000 r-xp 00000000 08:02 1417496
>  /lib64/librt-2.9.so
> 7f1ccac0d000-7f1ccae0c000 ---p 00008000 08:02 1417496
>  /lib64/librt-2.9.so
> 7f1ccae0c000-7f1ccae0d000 r--p 00007000 08:02 1417496
>  /lib64/librt-2.9.so
> 7f1ccae0d000-7f1ccae0e000 rw-p 00008000 08:02 1417496
>  /lib64/librt-2.9.so
> 7f1ccae0e000-7f1ccae23000 r-xp 00000000 08:02 1417457
>  /lib64/libnsl-2.9.so
> 7f1ccae23000-7f1ccb022000 ---p 00015000 08:02 1417457
> 7f1ccb022000-7f1ccb023000 r--p 00014000 08:02 1417457
> 7f1ccb023000-7f1ccb024000 rw-p 00015000 08:02 1417457
> 7f1ccb024000-7f1ccb026000 rw-p 7f1ccb024000 00:00 0
> 7f1ccb026000-7f1ccb07b000 r-xp 00000000 08:02 1417485
>  /lib64/libm-2.9.so
> 7f1ccb07b000-7f1ccb27a000 ---p 00055000 08:02 1417485
>  /lib64/libm-2.9.so
> 7f1ccb27a000-7f1ccb27b000 r--p 00054000 08:02 1417485
>  /lib64/libm-2.9.so
> 7f1ccb27b000-7f1ccb27c000 rw-p 00055000 08:02 1417485
>  /lib64/libm-2.9.so
> 7f1ccb27c000-7f1ccb291000 r-xp 00000000 08:02 1417270
>  /lib64/libz.so.1.2.3
> 7f1ccb291000-7f1ccb490000 ---p 00015000 08:02 1417270
> 7f1ccb490000-7f1ccb491000 r--p 00014000 08:02 1417270
> 7f1ccb491000-7f1ccb492000 rw-p 00015000 08:02 1417270
> 7f1ccb492000-7f1ccb494000 r-xp 00000000 08:02 1417482
>  /lib64/libdl-2.9.so
> 7f1ccb494000-7f1ccb694000 ---p 00002000 08:02 1417482
>  /lib64/libdl-2.9.so
> 7f1ccb694000-7f1ccb695000 r--p 00002000 08:02 1417482
>  /lib64/libdl-2.9.so
> 7f1ccb695000-7f1ccb696000 rw-p 00003000 08:02 1417482
>  /lib64/libdl-2.9.so
> 7f1ccb696000-7f1ccb7ea000 r-xp 00000000 08:02 521675
>  /usr/lib64/libxml2.so.2.7.1
> 7f1ccb7ea000-7f1ccb9e9000 ---p 00154000 08:02 521675
> 7f1ccb9e9000-7f1ccb9f1000 r--p 00153000 08:02 521675
> 7f1ccb9f1000-7f1ccb9f3000 rw-p 0015b000 08:02 521675
> 7f1ccb9f3000-7f1ccb9f4000 rw-p 7f1ccb9f3000 00:00 0
> 7f1ccb9f4000-7f1ccba12000 r-xp 00000000 08:02 1420584
>  /lib64/ld-2.9.so
> 7f1ccbbd3000-7f1ccbbd8000 rw-p 7f1ccbbd3000 00:00 0
> 7f1ccbc0f000-7f1ccbc11000 rw-p 7f1ccbc0f000 00:00 0
> 7f1ccbc11000-7f1ccbc12000 r--p 0001d000 08:02 1420584
>  /lib64/ld-2.9.so
> 7f1ccbc12000-7f1ccbc13000 rw-p 0001e000 08:02 1420584
>  /lib64/ld-2.9.so
> 7fffd651e000-7fffd6541000 rw-p 7ffffffdc000 00:00 0                      [stack]
> 7fffd65ff000-7fffd6600000 r-xp 7fffd65ff000 00:00 0                      [vdso]
> ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0
>  [vsyscall]
> Aborted
> On Fri, Nov 5, 2010 at 12:15 PM, Pavan Balaji <balaji at mcs.anl.gov> wrote:
>> Did you try 1.3? The attached program works fine with trunk.
>>  -- Pavan
>> On 11/05/2010 11:21 AM, Jeff Hammond wrote:
>>> I'm seeing an error when parallel jobs run with MPICH2 1.3a1 terminate.
>>> I see the problem with NWChem (attached) but also with the trivial code
>>> below.
>>> Jeff
>>> stdout and stderr
>>> jeff at localhost:~/eclipse/a1/trunk/benchmarks/mpi>  mpiexec -np 2
>>> MPI_Allreduce_tests.x
>>> Test 0: sum 1 out-of-place
>>>    0: in=1 out=1 ans=1 PASSED
>>> Test 1: sum 1 in-place
>>> Test 2: sum 2 out-of-place
>>>    0: in=1 out=2 ans=2 PASSED
>>> Test 3: sum 2 in-place
>>> Test 4: prod 1 out-of-place
>>>    0: in=1 out=0 ans=0 PASSED
>>> Test 5: prod 1 in-place
>>> Test 6: prod 2 out-of-place
>>> Test 7: prod 2 in-place
>>>    1: in=0 out=1 ans=1 PASSED
>>>    1: in=1 out=2 ans=2 PASSED
>>>    1: in=0 out=0 ans=0 PASSED
>>>    1: in=1 out=1 ans=1 PASSED
>>> 0x00007fffcb3ce169 ***
>>> /lib64/libc.so.6[0x7f5415e5b0c8]
>>> mpiexec[0x41908b]
>>> mpiexec[0x403a97]
>>> /lib64/libc.so.6(__libc_start_main+0xe6)[0x7f5415e05586]
>>> mpiexec[0x402f29]
>>> 00400000-00426000 r-xp 00000000 08:03 2426704
>>>   /software/mpich/mpich2-1.3a1-gnu-build/bin/mpiexec
>>> 00625000-00626000 r--p 00025000 08:03 2426704
>>> 00626000-00627000 rw-p 00026000 08:03 2426704
>>> 00627000-0064a000 rw-p 00627000 00:00 0
>>>  [heap]
>>> 7f5415bd0000-7f5415be5000 r-xp 00000000 08:02 1417264
>>> 7f5415be5000-7f5415de5000 ---p 00015000 08:02 1417264
>>> 7f5415de5000-7f5415de6000 r--p 00015000 08:02 1417264
>>> 7f5415de6000-7f5415de7000 rw-p 00016000 08:02 1417264
>>> 7f5415de7000-7f5415f36000 r-xp 00000000 08:02 1417222
>>>   /lib64/libc-2.9.so
>>> 7f5415f36000-7f5416136000 ---p 0014f000 08:02 1417222
>>>   /lib64/libc-2.9.so
>>> 7f5416136000-7f541613a000 r--p 0014f000 08:02 1417222
>>>   /lib64/libc-2.9.so
>>> 7f541613a000-7f541613b000 rw-p 00153000 08:02 1417222
>>>   /lib64/libc-2.9.so
>>> 7f541613b000-7f5416140000 rw-p 7f541613b000 00:00 0
>>> 7f5416140000-7f5416155000 r-xp 00000000 08:02 1417457
>>> 7f5416155000-7f5416354000 ---p 00015000 08:02 1417457
>>> 7f5416354000-7f5416355000 r--p 00014000 08:02 1417457
>>> 7f5416355000-7f5416356000 rw-p 00015000 08:02 1417457
>>> 7f5416356000-7f5416358000 rw-p 7f5416356000 00:00 0
>>> 7f5416358000-7f5416376000 r-xp 00000000 08:02 1420584
>>>   /lib64/ld-2.9.so
>>> 7f541653a000-7f541653c000 rw-p 7f541653a000 00:00 0
>>> 7f5416573000-7f5416575000 rw-p 7f5416573000 00:00 0
>>> 7f5416575000-7f5416576000 r--p 0001d000 08:02 1420584
>>>   /lib64/ld-2.9.so
>>> 7f5416576000-7f5416577000 rw-p 0001e000 08:02 1420584
>>>   /lib64/ld-2.9.so
>>> 7fffcb3b9000-7fffcb3cf000 rw-p 7ffffffe9000 00:00 0
>>>  [stack]
>>> 7fffcb3ff000-7fffcb400000 r-xp 7fffcb3ff000 00:00 0
>>>  [vdso]
>>>   [vsyscall]
>>> Aborted
>>> source
>>>  * The following is a notice of limited availability of the code, and
>>> disclaimer
>>>  * which must be included in the prologue of the code and in all source
>>> listings
>>>  * of the code.
>>>  * Copyright (c) 2010  Argonne Leadership Computing Facility, Argonne
>>> National
>>>  * Laboratory
>>>  * Permission is hereby granted to use, reproduce, prepare derivative
>>> works, and
>>>  * to redistribute to others.
>>>  *                          LICENSE
>>>  * Redistribution and use in source and binary forms, with or without
>>>  * modification, are permitted provided that the following conditions are
>>>  * met:
>>>  * - Redistributions of source code must retain the above copyright
>>>  *   notice, this list of conditions and the following disclaimer.
>>>  * - Redistributions in binary form must reproduce the above copyright
>>>  *   notice, this list of conditions and the following disclaimer listed
>>>  *   in this license in the documentation and/or other materials
>>>  *   provided with the distribution.
>>>  * - Neither the name of the copyright holders nor the names of its
>>>  *   contributors may be used to endorse or promote products derived from
>>>  *   this software without specific prior written permission.
>>>  * The copyright holders provide no reassurances that the source code
>>>  * provided does not infringe any patent, copyright, or any other
>>>  * intellectual property rights of third parties.  The copyright holders
>>>  * disclaim any liability to any recipient for claims brought against
>>>  * recipient by any third party for infringement of that parties
>>>  * intellectual property rights.
>>>  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>>>  * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
>>>  * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
>>>  * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
>>>  * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
>>>  * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
>>>  * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
>>>  * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
>>>  * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
>>>  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
>>>  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
>>> #include<stdio.h>
>>> #include<stdlib.h>
>>> #include<mpi.h>
>>>     int provided;
>>>     int rank, size;
>>>     int count;
>>>     int in, out, ans;
>>>     MPI_Init_thread(&argc,&argv, MPI_THREAD_MULTIPLE,&provided);
>>>     MPI_Comm_rank(MPI_COMM_WORLD,&rank);
>>>     MPI_Comm_size(MPI_COMM_WORLD,&size);
>>>     /* TESTING SUM OPERATOR */
>>>     if (rank==0) printf("Test %d: sum 1 out-of-place\n",count++);
>>>     in  = ( rank==0 ? 1 : 0 );
>>>     out = 0;
>>>     ans = 1;
>>>     MPI_Allreduce(&in,&out,1,MPI_INT,MPI_SUM,MPI_COMM_WORLD);
>>>     if (out==ans) printf("%4d: in=%d out=%d ans=%d PASSED
>>> \n",rank,in,out,ans);
>>>     else          printf("%4d: in=%d out=%d ans=%d FAILED
>>>     fflush(stdout);
>>>     if (rank==0) printf("Test %d: sum 1 in-place\n",count++);
>>>     out = in;
>>>     ans = 1;
>>>     MPI_Allreduce(MPI_IN_PLACE,&out,1,MPI_INT,MPI_SUM,MPI_COMM_WORLD);
>>>     fflush(stdout);
>>>     if (rank==0) printf("Test %d: sum 2 out-of-place\n",count++);
>>>     in  = 1;
>>>     out = 0;
>>>     ans = size;
>>>     fflush(stdout);
>>>     if (rank==0) printf("Test %d: sum 2 in-place\n",count++);
>>>     in  = 1;
>>>     out = in;
>>>     ans = size;
>>>     fflush(stdout);
>>>     /* TESTING PROD OPERATOR */
>>>     if (rank==0) printf("Test %d: prod 1 out-of-place\n",count++);
>>>     out = 0;
>>>     ans = 0;
>>>     MPI_Allreduce(&in,&out,1,MPI_INT,MPI_PROD,MPI_COMM_WORLD);
>>>     fflush(stdout);
>>>     if (rank==0) printf("Test %d: prod 1 in-place\n",count++);
>>>     out = in;
>>>     ans = 0;
>>>     MPI_Allreduce(MPI_IN_PLACE,&out,1,MPI_INT,MPI_PROD,MPI_COMM_WORLD);
>>> \n",rank,in,out,ans);;
>>>     fflush(stdout);
>>>     if (rank==0) printf("Test %d: prod 2 out-of-place\n",count++);
>>>     in  = 1;
>>>     out = 0;
>>>     ans = 1;
>>>     fflush(stdout);
>>>     if (rank==0) printf("Test %d: prod 2 in-place\n",count++);
>>>     in  = 1;
>>>     out = in;
>>>     ans = 1;
>>>     fflush(stdout);
>>>     /* END OF TESTS */
>>>     MPI_Finalize();
>>>     return 0;
>> Pavan Balaji
>> http://www.mcs.anl.gov/~balaji
> Jeff Hammond
> jhammond at alcf.anl.gov / (630) 252-5381
> http://www.linkedin.com/in/jeffhammond
Jeff Hammond
