[mpich-discuss] *** glibc detected *** mpiexec: munmap_chunk(): invalid pointer: 0x00007fff1d578184 ***
    Jeff Hammond
    jhammond at mcs.anl.gov
    Fri Nov  5 11:21:19 CDT 2010
I'm seeing an error when parallel jobs run with MPICH2 1.3a1 terminate.
I see the problem with NWChem (attached) but also with the trivial code below.
Jeff
stdout and stderr
jeff at localhost:~/eclipse/a1/trunk/benchmarks/mpi> mpiexec -np 2
MPI_Allreduce_tests.x
Test 0: sum 1 out-of-place
   0: in=1 out=1 ans=1 PASSED
Test 1: sum 1 in-place
Test 2: sum 2 out-of-place
   0: in=1 out=2 ans=2 PASSED
Test 3: sum 2 in-place
Test 4: prod 1 out-of-place
   0: in=1 out=0 ans=0 PASSED
Test 5: prod 1 in-place
Test 6: prod 2 out-of-place
Test 7: prod 2 in-place
   1: in=0 out=1 ans=1 PASSED
   1: in=1 out=2 ans=2 PASSED
   1: in=0 out=0 ans=0 PASSED
   1: in=1 out=1 ans=1 PASSED
0x00007fffcb3ce169 ***
======= Backtrace: =========
/lib64/libc.so.6[0x7f5415e5b0c8]
mpiexec[0x41908b]
mpiexec[0x403a97]
/lib64/libc.so.6(__libc_start_main+0xe6)[0x7f5415e05586]
mpiexec[0x402f29]
======= Memory map: ========
00400000-00426000 r-xp 00000000 08:03 2426704
  /software/mpich/mpich2-1.3a1-gnu-build/bin/mpiexec
00625000-00626000 r--p 00025000 08:03 2426704
00626000-00627000 rw-p 00026000 08:03 2426704
00627000-0064a000 rw-p 00627000 00:00 0                                  [heap]
7f5415bd0000-7f5415be5000 r-xp 00000000 08:02 1417264
  /lib64/libgcc_s.so.1
7f5415be5000-7f5415de5000 ---p 00015000 08:02 1417264
7f5415de5000-7f5415de6000 r--p 00015000 08:02 1417264
7f5415de6000-7f5415de7000 rw-p 00016000 08:02 1417264
7f5415de7000-7f5415f36000 r-xp 00000000 08:02 1417222
  /lib64/libc-2.9.so
7f5415f36000-7f5416136000 ---p 0014f000 08:02 1417222
  /lib64/libc-2.9.so
7f5416136000-7f541613a000 r--p 0014f000 08:02 1417222
  /lib64/libc-2.9.so
7f541613a000-7f541613b000 rw-p 00153000 08:02 1417222
  /lib64/libc-2.9.so
7f541613b000-7f5416140000 rw-p 7f541613b000 00:00 0
7f5416140000-7f5416155000 r-xp 00000000 08:02 1417457
  /lib64/libnsl-2.9.so
7f5416155000-7f5416354000 ---p 00015000 08:02 1417457
7f5416354000-7f5416355000 r--p 00014000 08:02 1417457
7f5416355000-7f5416356000 rw-p 00015000 08:02 1417457
7f5416356000-7f5416358000 rw-p 7f5416356000 00:00 0
7f5416358000-7f5416376000 r-xp 00000000 08:02 1420584
  /lib64/ld-2.9.so
7f541653a000-7f541653c000 rw-p 7f541653a000 00:00 0
7f5416573000-7f5416575000 rw-p 7f5416573000 00:00 0
7f5416575000-7f5416576000 r--p 0001d000 08:02 1420584
  /lib64/ld-2.9.so
7f5416576000-7f5416577000 rw-p 0001e000 08:02 1420584
  /lib64/ld-2.9.so
7fffcb3b9000-7fffcb3cf000 rw-p 7ffffffe9000 00:00 0                      [stack]
7fffcb3ff000-7fffcb400000 r-xp 7fffcb3ff000 00:00 0                      [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0
  [vsyscall]
Aborted
source
 * The following is a notice of limited availability of the code, and disclaimer
 * which must be included in the prologue of the code and in all source listings
 * of the code.
 * Copyright (c) 2010  Argonne Leadership Computing Facility, Argonne National
 * Laboratory
 * Permission is hereby granted to use, reproduce, prepare derivative works, and
 * to redistribute to others.
 *                          LICENSE
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions are
 * met:
 * - Redistributions of source code must retain the above copyright
 *   notice, this list of conditions and the following disclaimer.
 * - Redistributions in binary form must reproduce the above copyright
 *   notice, this list of conditions and the following disclaimer listed
 *   in this license in the documentation and/or other materials
 *   provided with the distribution.
 * - Neither the name of the copyright holders nor the names of its
 *   contributors may be used to endorse or promote products derived from
 *   this software without specific prior written permission.
 * The copyright holders provide no reassurances that the source code
 * provided does not infringe any patent, copyright, or any other
 * intellectual property rights of third parties.  The copyright holders
 * disclaim any liability to any recipient for claims brought against
 * recipient by any third party for infringement of that parties
 * intellectual property rights.
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
 * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
 * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
 * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
 * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
 * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
 * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <stdio.h>
#include <stdlib.h>
#include <mpi.h>
int main(int argc, char **argv)
    int provided;
    int rank, size;
    int count;
    int in, out, ans;
    MPI_Init_thread(&argc, &argv, MPI_THREAD_MULTIPLE, &provided);
    MPI_Comm_rank(MPI_COMM_WORLD, &rank);
    MPI_Comm_size(MPI_COMM_WORLD, &size);
    MPI_Barrier(MPI_COMM_WORLD);
    /* TESTING SUM OPERATOR */
    if (rank==0) printf("Test %d: sum 1 out-of-place\n",count++);
    in  = ( rank==0 ? 1 : 0 );
    out = 0;
    ans = 1;
    MPI_Allreduce(&in,&out,1,MPI_INT,MPI_SUM,MPI_COMM_WORLD);
    if (out==ans) printf("%4d: in=%d out=%d ans=%d PASSED \n",rank,in,out,ans);
    else          printf("%4d: in=%d out=%d ans=%d FAILED \n",rank,in,out,ans);
    fflush(stdout);
    if (rank==0) printf("Test %d: sum 1 in-place\n",count++);
    out = in;
    ans = 1;
    MPI_Allreduce(MPI_IN_PLACE,&out,1,MPI_INT,MPI_SUM,MPI_COMM_WORLD);
    fflush(stdout);
    if (rank==0) printf("Test %d: sum 2 out-of-place\n",count++);
    in  = 1;
    out = 0;
    ans = size;
    fflush(stdout);
    if (rank==0) printf("Test %d: sum 2 in-place\n",count++);
    in  = 1;
    out = in;
    ans = size;
    fflush(stdout);
    /* TESTING PROD OPERATOR */
    if (rank==0) printf("Test %d: prod 1 out-of-place\n",count++);
    out = 0;
    ans = 0;
    MPI_Allreduce(&in,&out,1,MPI_INT,MPI_PROD,MPI_COMM_WORLD);
    fflush(stdout);
    if (rank==0) printf("Test %d: prod 1 in-place\n",count++);
    out = in;
    ans = 0;
    MPI_Allreduce(MPI_IN_PLACE,&out,1,MPI_INT,MPI_PROD,MPI_COMM_WORLD);
    else          printf("%4d: in=%d out=%d ans=%d FAILED \n",rank,in,out,ans);;
    fflush(stdout);
    if (rank==0) printf("Test %d: prod 2 out-of-place\n",count++);
    in  = 1;
    out = 0;
    ans = 1;
    fflush(stdout);
    if (rank==0) printf("Test %d: prod 2 in-place\n",count++);
    in  = 1;
    out = in;
    ans = 1;
    fflush(stdout);
    /* END OF TESTS */
    MPI_Finalize();
    return 0;
Jeff Hammond
jhammond at alcf.anl.gov / (630) 252-5381
http://www.linkedin.com/in/jeffhammond
