[mpich-discuss] try to install MPICH2 on SGI under local account
Pavan Balaji balaji at mcs.anl.gov
Fri May 28 12:11:52 CDT 2010
The good news is that the simplemake step is not being executed anymore.
The atomic-primitives part is not fixed yet, and we are working on it.
But that shouldn't affect you; you can continue to use
--with-atomic-primitives=no for the time being.
The error in make looks like a different failure possibly related to the
threading changes made recently (though I didn't look through the logs
closely).
Dave: can you look into this?
  -- Pavan
On 05/28/2010 11:51 AM, Rui Mei wrote:
> Hi, Paven,
> I tried this out. But it still gave me error.
> I first tried ./configure --prefix=/u/home/rum06003/mpi
> --with-device=ch3:sock 2>&1 | tee c1.txt and it gave me error (see
> c1.txt) and suggest to use --with-atomic-primitives=no option.
> So I then tried ./configure --prefix=/u/home/rum06003/mpi
> --with-atomic-primitives=no 2>&1 | tee c.txt (it's ok, see c.txt)
> Then I executed: make 2>&1 | tee m.txt (it gave error, see m.txt)
> At last I executed: make install 2>&1 | tee mi.txt (it also gave
> error, see mi.txt)
> Thank you for any help.
> Rui
> On 5/28/10, Pavan Balaji <balaji at mcs.anl.gov> wrote:
>> I've just uploaded a new snapshot (r6756). Can you try it out?
>>   -- Pavan
>> On 05/28/2010 09:06 AM, Mei, Rui wrote:
>>> Hi, Pavan,
>>> I went to the trunk directory and found a new release mpich2-trunk-r6754
>>> today. But I still could not find configure file in the tarball. do you
>>> mean that it still needs some investigation?
>>> Thank you for your continuous help. I appreciate that very much.
>>> Rui
>>> ________________________________________
>>> From: mpich-discuss-bounces at mcs.anl.gov
>>> [mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Pavan Balaji
>>> [balaji at mcs.anl.gov]
>>> Sent: Friday, May 28, 2010 8:10 AM
>>> To: mpich-discuss at mcs.anl.gov
>>> Subject: Re: [mpich-discuss] try to install MPICH2 on SGI under local
>>> account
>>> I poked around on this a bit, but it seems to require some
>>> investigation. I've created a ticket and cc'ed you on it. For others who
>>> wish to follow along, the ticket is available here:
>>> http://trac.mcs.anl.gov/projects/mpich2/ticket/1054. Please add yourself
>>> to the cc list if you are interested.
>>> Thanks,
>>>   -- Pavan
>>> On 05/27/2010 03:01 PM, Mei, Rui wrote:
>>>> Thank you very much. Please let me know when it is done. I am looking
>>>> forward to test it.
>>>> Rui
>>>> Sent: Thursday, May 27, 2010 2:51 PM
>>>> account
>>>> On 05/27/2010 01:40 PM, Mei, Rui wrote:
>>>>> I downloaded this version mpich2-trunk-r6751.tar.gz, but there is even
>>>>> no configure file in this tar ball.
>>>>> Or I should try the second latest version mpich2-trunk-r6750.tar.gz ?
>>>> Oops, my bad. Hold on, I'm fixing it.
>>>>   -- Pavan
>>>> Pavan Balaji
>>>> http://www.mcs.anl.gov/~balaji
>>>> _______________________________________________
>>>> mpich-discuss mailing list
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>> Pavan Balaji
>> Pavan Balaji
Pavan Balaji
