[mpich-discuss] [mpich2-dev] I can not make MPI recognizes a	dual core
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Wed May 26 12:47:30 CDT 2010
 Did "mpiexec -n 2 hostname" work ? Is your machine 32-bit or 64-bit (The 32-bit installations are provided with pre-compiled sample MPI programs that you can try, c:\progra~1\mpich2\examples\cpi.exe OR you can download https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/examples/cpi.c and try it)?
Jayesh
----- Original Message -----
From: "Yessica Brinkmann" <yessica.brinkmann at gmail.com>
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Cc: mpich-discuss at mcs.anl.gov
Sent: Wednesday, May 26, 2010 11:34:36 AM GMT -06:00 US/Canada Central
Subject: Re: [mpich2-dev] I can not make MPI recognizes a dual core
Hi, Very thanks for your response. MPI is an admin user. I intall
MPICH for only an user because a teacher give me this tip.
When mpiexec prompts for the username I press the enter key, and then
I write the password.
The system response to me:
job aborted:
rank: node: exit code [: error message]
0: User-PC: -1073740777: process 0 exited without calling finalize
1: User-PC: 123
I do not have in my team who has installed/used MPICH2, I sorry.
I will thanks any help.
Yessica Brinkmann
2010/5/26 Jayesh Krishna <jayesh at mcs.anl.gov>:
> Hi,
>  Is the new user, MPI, an admin user ? How did you install MPICH2 for only that user ? I am still surprised that you have to install smpd explicitly (that the installer does not install it for you).
>  MPICH2 runtime system requires user credentials to launch an MPI job. Looks like you are logged on as "User-PC\MPI". Try entering the password (for user "User-PC\MPI") without entering the username (When mpiexec prompts for the username just press the enter key).
>  I would also recommend getting help from your sysadmin regarding installation of MPICH2 (Or better anyone else in your team who has installed/used MPICH2).
> Regards,
> Jayesh
> To: jayesh at mcs.anl.gov
> Sent: Tuesday, May 25, 2010 9:14:53 PM GMT -06:00 US/Canada Central
> Hi, very thanks for your response.
> I created a new user called MPI and I reinstalled the MPICH2 only for
> this user, and I executed the sentences that you say for me.
> When I write
> smpd -uninstall
> Stopping MPICH2 Process Manager, Argonne National Lab.
> MPICH2 Process Manager, Argonne National Lab stopped.
> MPICH2 Process Manager, Argonne National Lab removed.
> When I write:
> smpd -install -phrase behappy
> MPICH2 Process Manager, Argonne National Lab installed.
> When I write:
> smpd -status
> smpd running on User-PC
> When I write:
> User credentials needed to launch processes:
> account(domain\user) [User-PC\MPI]:
> And at this point I does not how I should write, I try with MPI or
> User-PC\MPI, but does not work.
> Then the system ask to me for the password:
> I write the password that I use for the MPI user, and the system response to me:
> Credentials for MPI rejected connecting to User-PC.
> Aborting: Unable to connect to User-PC
> I think this is because I does not known how I should write when the
> system ask to me:
> Yessica Brinkmann
> 2010/5/25  <jayesh at mcs.anl.gov>:
>> Hi,
>>  This is strange... With the information provided by you I can only make the following suggestions (I can provide better suggestions if you provide me more details),
>> # Uninstall smpd from an ADMIN command prompt by typing, "smpd -uninstall"
>> # Install smpd from the ADMIN command prompt by typing, "smpd -install -phrase behappy"
>> # Check status of smpd from the ADMIN command prompt by typing, "smpd -status"
>> # Run a non-MPI program from the ADMIN command prompt by typing, "mpiexec -n 2 hostname"
>> Regards,
>> Jayesh
>> Sent: Tuesday, May 25, 2010 3:10:40 PM GMT -06:00 US/Canada Central
>> Hi,
>> I reinstalled MPICH and I does not modified the default SMPD
>> passphrase provided in the user input textbox, it is behappy.
>> After the installation I try to run a non-MPI program (mpiexec -n 2
>> hostname) and I have the same error:
>> I have the output:
>> Please specify an authentication passphrase for smpd: I write behappy
>> Aborting: unable to connect to User-PC
>> Very thanks.
>> Yessica Brinkmann
>> 2010/5/25 Yessica Brinkmann <yessica.brinkmann at gmail.com>:
>>> Hi,
>>> Yes, I modified the default SMPD passphrase provided in the user input
>>> textbox. The error is because I modified the passphrase or because I
>>> provided an incorrect passphrase at the command line? Maybe I provided
>>> an incorrect passphrase at the command line, maybe I should to
>>> reinstall the MPICH2 and annotate the passphrase.
>>> Thanks very much.
>>> Yessica Brinkmann
>>>> Hi,
>>>>  The error message shows that you did not specify an authentication passphrase for SMPD. If the installation process was successful you should not be seeing this message.
>>>>  During the installation process, the MPICH2 installer requests for the SMPD passphrase. A default SMPD passphrase is provided in the user input textbox for convenience. Did you delete/remove the default passphrase during the installation step ?
>>>>  Can you reply with details the steps used to install MPICH2 (You can add inputs to the installation steps that I provided in my previous email)? Also specify, in detail, if you modified any default input values during the installation process.
>>>> Regards,
>>>> Jayesh
>>>> Sent: Tuesday, May 25, 2010 11:18:27 AM GMT -06:00 US/Canada Central
>>>> I reinstalled the MPICH2 by the steps that you say to me.
>>>> I have the output:
>>>> I write the authentication passphrase and the system response to me:
>>>> Very thanks.
>>>> Yessica Brinkmann
>>>>> Hi,
>>>>>  I would recommend uninstalling MPICH2 and installing it again from the administrator command prompt by following the steps below.
>>>>> # Download the latest version of MPICH2 (http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads).
>>>>> # Open an administrator command prompt (Right-click on the command prompt icon and select "Run as administrator")
>>>>> # From the admin command prompt use the msiexec utility to uninstall MPICH2 (eg: Type "msiexec /x mpich2-1.2.1p1-win-ia32.msi" to uninstall MPICH2 using the mpich2-1.2.1p1-win-ia32.msi installer)
>>>>> # The above command will bring up the Installer GUI to uninstall MPICH2. Follow the steps to uninstall MPICH2.
>>>>> # From the admin command prompt use the msiexec utility to install MPICH2 (eg: Type "msiexec /i mpich2-1.2.1p1-win-ia32.msi" to install MPICH2 using the mpich2-1.2.1p1-win-ia32.msi installer)
>>>>> # The above command will bring up the Installer GUI to install MPICH2. Follow the installer steps to install MPICH2.
>>>>> # After the installation try to run a non-MPI program (mpiexec -n 2 hostname) . If the job launcher, mpiexec, requests for a username/password please provide the same (When specifying the username/password make sure that you specify the domain name if the user is a domain user).
>>>>>  Let us know the results.
>>>>> Regards,
>>>>> Jayesh
>>>>> Sent: Monday, May 24, 2010 5:28:07 PM GMT -06:00 US/Canada Central
>>>>> I sorry, I now open an administrative command prompt.
>>>>> Now, when I write:
>>>>> smpd -start
>>>>> I have the output:
>>>>> OpenService failed:
>>>>> El servicio especificado no existe como servicio instalado (error 1060).
>>>>> When I write:
>>>>> smpd -install
>>>>> I have the output:
>>>>> MPICH Process Manager, Argonne National Lab installed.
>>>>> Now, I write:
>>>>> smpd -start
>>>>> I have the output:
>>>>> MPICH Process Manager, Argonne National Lab failed to start.
>>>>> Ya se está ejecutando una instancia de este servicio (error 1056)
>>>>> And when I write:
>>>>> smpd -status
>>>>> I have the output:
>>>>> And when I write:
>>>>> I have the output:
>>>>> Yessica Brinkmann
>>>>> 2010/5/24 Jayesh Krishna <jayesh at mcs.anl.gov>:
>>>>>> Hi,
>>>>>>  This is strange. From the error messages it looks like you don't have admin privileges. Are you able to open an administrative command prompt (Right-click on command prompt icon - select "Run as administrator")?
>>>>>>  What is the output when you type "smpd -install" from the admin command prompt (You have to run the command from an administrator command prompt)?
>>>>>> Regards,
>>>>>> Jayesh
>>>>>> Sent: Monday, May 24, 2010 5:02:14 PM GMT -06:00 US/Canada Central
>>>>>> Hi, very thanks for your interest.
>>>>>> When I type smpd -start the system response to me:
>>>>>> OpenSCManager failed:
>>>>>> Access denied (error 5)
>>>>>> And when I type smpd -uninstall I have the same error:
>>>>>> Very thanks, I will thanks any help.
>>>>>> Yessica Brinkmann
>>>>>> 2010/5/24  <jayesh at mcs.anl.gov>:
>>>>>>> Hi,
>>>>>>>  Try starting smpd from the administrative command prompt (Type "smpd -start" from the administrative command prompt) and let us know the result.
>>>>>>>  If starting smpd (the step above) fails, try uninstalling+installing smpd from the admin command prompt (Type "smpd -uninstall" to uninstall SMPD and then type "smpd -install" to install SMPD) and let us know the results.
>>>>>>> Regards,
>>>>>>> Jayesh
>>>>>>> Sent: Monday, May 24, 2010 4:40:44 PM GMT -06:00 US/Canada Central
>>>>>>> Hi, Very thanks for your response!!!
>>>>>>> I does not have error messages during MPICH2 installation. I turn off
>>>>>>> the firewall for run mpiexec -n 2 hostname.
>>>>>>> The output of "smpd -status" from an administrative command prompt is:
>>>>>>> no smpd running on User-PC
>>>>>>> I try running mpiexec -n 2 hostname from the administrative command
>>>>>>> prompt and I have the same error:
>>>>>>> Error while connectig to host, No se puede establecer una conexión ya
>>>>>>> que el equipo de destino denegó expresamente dicha conexión (10061)
>>>>>>> Connect on sock(host=User-PC, port=8676) failed, exhaused all end
>>>>>>> points Unable to connect to 'User-PC:8678', sock error: Error = -1
>>>>>>> Very thanks. I will thanks any help.
>>>>>>> Yessica Brinkmann
>>>>>>>> Hi,
>>>>>>>>  Did you get any error messages during MPICH2 installation ? Do you have any firewalls running on your machine (If so, turn off the firewall and re-run "mpiexec -n 2 hostname")?
>>>>>>>>  What is the output of "smpd -status" (Type "smpd -status" from an administrative command prompt)? Can you try running "mpiexec -n 2 hostname" from the administrative command prompt ?
>>>>>>>> Regards,
>>>>>>>> Jayesh
>>>>>>>> Sent: Monday, May 24, 2010 4:03:51 PM GMT -06:00 US/Canada Central
>>>>>>>> Hi, Very thanks for your response and your interest.
>>>>>>>> I do all that you say to me, I reinstalled MPICH2.
>>>>>>>> I try to run a non-MPI program (mpiexec -n 2 hostname) and I have the
>>>>>>>> same error:
>>>>>>>> Yessica Brinkmann
>>>>>>>>> Hi,
>>>>>>>>>  Did you get any errors during the installation of MPICH2 ?
>>>>>>>>>  I would recommend the following,
>>>>>>>>> # Uninstall MPICH2 from your system.
>>>>>>>>> # Open an administrative command prompt (Right-click on the command prompt icon and select "Run as administrator")
>>>>>>>>> # From the administrative command prompt use the msiexec utility to install MPICH2 (eg: Type "msiexec /i mpich2-1.2.1p1-win-ia32.msi" to install MPICH2 using the mpich2-1.2.1p1-win-ia32.msi installer)
>>>>>>>>> Regards,
>>>>>>>>> Jayesh
>>>>>>>>> (PS: Please reply to this email for further correspondence regarding this request - I have copied the email to mpich-discuss instead of mpich2-dev since the discussion is not related to mpich2 dev )
>>>>>>>>> To: mpich2-dev at mcs.anl.gov
>>>>>>>>> Sent: Friday, May 21, 2010 7:08:41 PM GMT -06:00 US/Canada Central
>>>>>>>>> Very thanks for your response. I am using windows 7 and I execute at
>>>>>>>>> windows comman line mpiexec -np 2 my_program.exe that you say to me,
>>>>>>>>> at the MPICH2\bin directory.
>>>>>>>>> And then I write the authentication passphrase that I write on the
>>>>>>>>> MPICH instalation and the system response to me:
>>>>>>>>> I will thanks you very much any help.
>>>>>>>>> Thanks,
>>>>>>>>> Yessica Brinkmann
>>>>>>>>> 2010/5/21 Lisandro Dalcin <dalcinl at gmail.com>:
>>>>>>>>>> On 21 May 2010 14:07, Yessica Brinkmann <yessica.brinkmann at gmail.com> wrote:
>>>>>>>>>>> Hello.
>>>>>>>>>> Hello, Yessica
>>>>>>>>>>> I am using MPICH2. I am writing my first program in MPI.
>>>>>>>>>> This mailing list is related to DEVELOPMENT of MPICH2, general (and
>>>>>>>>>> pretty basic, in your case) user-level questions about MPI should be
>>>>>>>>>> directed elsewhere.
>>>>>>>>>>> I write the sentences:
>>>>>>>>>>> int id;
>>>>>>>>>>> MPI_Comm_rank (MPI_COMM_WORLD, & id);
>>>>>>>>>>> if (id == 0)
>>>>>>>>>>> / * Master task * /
>>>>>>>>>>> else
>>>>>>>>>>> / * Worker task * /
>>>>>>>>>>> And I write other sentences. The issue is that it does not recognize a
>>>>>>>>>>> DualCore processor, and takes the machine as it only has one
>>>>>>>>>>> processor, indeed, never enters the else.
>>>>>>>>>>> I would appreciate very much any help.
>>>>>>>>>>> Sincerely,
>>>>>>>>>>> Yessica Brinkmann
>>>>>>>>>> After compiling your program:
>>>>>>>>>> $ mpicc sourcecode.c -o myprogram
>>>>>>>>>> you have to run it like this (requires first to "mpdboot"):
>>>>>>>>>> $ mpiexec -n 2 ./myprogram
>>>>>>>>>> of like this:
>>>>>>>>>> $ mpiexec.hydra -n 2 ./myprogram
>>>>>>>>>> Lisandro Dalcin
>>>>>>>>>> CIMEC (INTEC/CONICET-UNL)
>>>>>>>>>> Predio CONICET-Santa Fe
>>>>>>>>>> Colectora RN 168 Km 472, Paraje El Pozo
>>>>>>>>>> Tel: +54-342-4511594 (ext 1011)
>>>>>>>>>> Tel/Fax: +54-342-4511169
