[mpich-discuss] make fails with undefined reference	VALGRIND_CHECK_MEM_IS_ADDRESSABLE
    Dave Goodell
    goodell at mcs.anl.gov
    Tue May 25 14:04:04 CDT 2010
FWIW, I've fixed this issue in the trunk in r6730.  The detection logic is better, and you can now pass --without-valgrind at configure time to forcibly disable it.
-Dave
On May 18, 2010 , at 12:31 PM CDT, Dave Goodell wrote:
> Yeah, that's the reason.  I'll make some adjustments to the build system to handle this.
> -Dave
> On May 18, 2010, at 11:50 AM, Wei-keng Liao wrote:
>> It is valgrind-2.4.0
>> Wei-keng
>> On May 18, 2010, at 11:45 AM, Anthony Chan wrote:
>>> How about "valgrind --version" ?
>>> ----- "Wei-keng Liao" <wkliao at ece.northwestern.edu> wrote:
>>>> I checked valgrind.h on my system, but do not know how to tell the
>>>> valgrind version. Let me know if you have an idea.
>>>> Wei-keng
>>>> On May 18, 2010, at 10:51 AM, Dave Goodell wrote:
>>>>> What version of valgrind do you have installed?
>>>>> I suspect that your version of valgrind is older than anything that
>>>>> we've tested with and is slipping between the gap of "is valgrind.h
>>>>> available" and "does valgrind.h work".  I can strengthen the
>>>>> configure test if I have an idea of what version of valgrind you
>>>> have.
>>>>> In the interim, the best workaround for you is probably to either
>>>>> remove "meminit" from your "--enable-g" arg, hack up the configure
>>>>> tests for valgrind so that they always fail, or delete lines 25-35
>>>>> of "src/include/mpiu_valgrind.h".
>>>>> -Dave
>>>>> On May 18, 2010, at 10:38 AM, Wei-keng Liao wrote:
>>>>>> When running make of mpich2-1.2.1p1, I got an error complaining
>>>>>> undefined reference to VALGRIND_CHECK_MEM_IS_ADDRESSABLE. Please
>>>>>> see the attached standard outputs from configure and make.
>>>>>> The configure command and environment variables used are also given
>>>>>> in out.configure file.
>>>>>> I am using GNU compilers, gcc and gfortran, to build MPICH2.
>>>>>> gcc version 4.0.2 20051125 (Red Hat 4.0.2-8)
>>>>>> % rpm -q glibc
>>>>>> glibc-2.3.6-3
>>>>>> % uname -a
>>>>>> Linux 2.6.17-1.2142_FC4smp #1 SMP Tue Jul 11 22:57:02 EDT 2006 i686
>>>>>> athlon i386 GNU/Linux
>>>>>> Wei-keng
>>>>>> <out.configure><out.make>
>>>>>> _______________________________________________
>>>>>> mpich-discuss mailing list
>>>>>> mpich-discuss at mcs.anl.gov
>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
