[mpich-discuss] [mpich2-dev] I can not make MPI recognizes a	dual core
    jayesh at mcs.anl.gov
    Mon May 24 16:46:37 CDT 2010
 Try starting smpd from the administrative command prompt (Type "smpd -start" from the administrative command prompt) and let us know the result.
 If starting smpd (the step above) fails, try uninstalling+installing smpd from the admin command prompt (Type "smpd -uninstall" to uninstall SMPD and then type "smpd -install" to install SMPD) and let us know the results.
Jayesh
----- Original Message -----
From: "Yessica Brinkmann" <yessica.brinkmann at gmail.com>
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Cc: mpich-discuss at mcs.anl.gov
Sent: Monday, May 24, 2010 4:40:44 PM GMT -06:00 US/Canada Central
Subject: Re: [mpich2-dev] I can not make MPI recognizes a dual core
Hi, Very thanks for your response!!!
I does not have error messages during MPICH2 installation. I turn off
the firewall for run mpiexec -n 2 hostname.
The output of "smpd -status" from an administrative command prompt is:
no smpd running on User-PC
I try running mpiexec -n 2 hostname from the administrative command
prompt and I have the same error:
Error while connectig to host, No se puede establecer una conexión ya
que el equipo de destino denegó expresamente dicha conexión (10061)
Connect on sock(host=User-PC, port=8676) failed, exhaused all end
points Unable to connect to 'User-PC:8678', sock error: Error = -1
Very thanks. I will thanks any help.
Yessica Brinkmann
2010/5/24 Jayesh Krishna <jayesh at mcs.anl.gov>:
> Hi,
>  Did you get any error messages during MPICH2 installation ? Do you have any firewalls running on your machine (If so, turn off the firewall and re-run "mpiexec -n 2 hostname")?
>  What is the output of "smpd -status" (Type "smpd -status" from an administrative command prompt)? Can you try running "mpiexec -n 2 hostname" from the administrative command prompt ?
> Regards,
> Jayesh
> To: jayesh at mcs.anl.gov
> Sent: Monday, May 24, 2010 4:03:51 PM GMT -06:00 US/Canada Central
> Hi, Very thanks for your response and your interest.
> I do all that you say to me, I reinstalled MPICH2.
> I try to run a non-MPI program (mpiexec -n 2 hostname) and I have the
> same error:
> Yessica Brinkmann
> 2010/5/24  <jayesh at mcs.anl.gov>:
>> Hi,
>>  Did you get any errors during the installation of MPICH2 ?
>>  I would recommend the following,
>> # Uninstall MPICH2 from your system.
>> # Download the latest version of MPICH2 (http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads).
>> # Open an administrative command prompt (Right-click on the command prompt icon and select "Run as administrator")
>> # From the administrative command prompt use the msiexec utility to install MPICH2 (eg: Type "msiexec /i mpich2-1.2.1p1-win-ia32.msi" to install MPICH2 using the mpich2-1.2.1p1-win-ia32.msi installer)
>> # The above command will bring up the Installer GUI to install MPICH2. Follow the installer steps to install MPICH2.
>> # After the installation try to run a non-MPI program (mpiexec -n 2 hostname) . If the job launcher, mpiexec, requests for a username/password please provide the same (When specifying the username/password make sure that you specify the domain name if the user is a domain user).
>>  Let us know the results.
>> Regards,
>> Jayesh
>> (PS: Please reply to this email for further correspondence regarding this request - I have copied the email to mpich-discuss instead of mpich2-dev since the discussion is not related to mpich2 dev )
>> To: mpich2-dev at mcs.anl.gov
>> Sent: Friday, May 21, 2010 7:08:41 PM GMT -06:00 US/Canada Central
>> Very thanks for your response. I am using windows 7 and I execute at
>> windows comman line mpiexec -np 2 my_program.exe that you say to me,
>> at the MPICH2\bin directory.
>> The system response to me:
>> Please specify an authentication passphrase for smpd:
>> And then I write the authentication passphrase that I write on the
>> MPICH instalation and the system response to me:
>> I will thanks you very much any help.
>> Thanks,
>> Yessica Brinkmann
>> 2010/5/21 Lisandro Dalcin <dalcinl at gmail.com>:
>>> On 21 May 2010 14:07, Yessica Brinkmann <yessica.brinkmann at gmail.com> wrote:
>>>> Hello.
>>> Hello, Yessica
>>>> I am using MPICH2. I am writing my first program in MPI.
>>> This mailing list is related to DEVELOPMENT of MPICH2, general (and
>>> pretty basic, in your case) user-level questions about MPI should be
>>> directed elsewhere.
>>>> I write the sentences:
>>>> int id;
>>>> MPI_Comm_rank (MPI_COMM_WORLD, & id);
>>>> if (id == 0)
>>>> / * Master task * /
>>>> else
>>>> / * Worker task * /
>>>> And I write other sentences. The issue is that it does not recognize a
>>>> DualCore processor, and takes the machine as it only has one
>>>> processor, indeed, never enters the else.
>>>> I would appreciate very much any help.
>>>> Sincerely,
>>>> Yessica Brinkmann
>>> After compiling your program:
>>> $ mpicc sourcecode.c -o myprogram
>>> you have to run it like this (requires first to "mpdboot"):
>>> $ mpiexec -n 2 ./myprogram
>>> of like this:
>>> $ mpiexec.hydra -n 2 ./myprogram
>>> Lisandro Dalcin
>>> CIMEC (INTEC/CONICET-UNL)
>>> Predio CONICET-Santa Fe
>>> Colectora RN 168 Km 472, Paraje El Pozo
>>> Tel: +54-342-4511594 (ext 1011)
>>> Tel/Fax: +54-342-4511169
