[mpich-discuss] [mpich2-dev] I can not make MPI recognizes a dual core
Yessica Brinkmann yessica.brinkmann at gmail.com
Mon May 24 16:03:51 CDT 2010
Hi, Very thanks for your response and your interest.
I do all that you say to me, I reinstalled MPICH2.
I try to run a non-MPI program (mpiexec -n 2 hostname) and I have the
same error:
Error while connectig to host, No se puede establecer una conexión ya
que el equipo de destino denegó expresamente dicha conexión (10061)
Connect on sock(host=User-PC, port=8676) failed, exhaused all end
points Unable to connect to 'User-PC:8678', sock error: Error = -1
I will thanks any help.
Yessica Brinkmann
2010/5/24  <jayesh at mcs.anl.gov>:
> Hi,
>  Did you get any errors during the installation of MPICH2 ?
>  I would recommend the following,
> # Uninstall MPICH2 from your system.
> # Download the latest version of MPICH2 (http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads).
> # Open an administrative command prompt (Right-click on the command prompt icon and select "Run as administrator")
> # From the administrative command prompt use the msiexec utility to install MPICH2 (eg: Type "msiexec /i mpich2-1.2.1p1-win-ia32.msi" to install MPICH2 using the mpich2-1.2.1p1-win-ia32.msi installer)
> # The above command will bring up the Installer GUI to install MPICH2. Follow the installer steps to install MPICH2.
> # After the installation try to run a non-MPI program (mpiexec -n 2 hostname) . If the job launcher, mpiexec, requests for a username/password please provide the same (When specifying the username/password make sure that you specify the domain name if the user is a domain user).
>  Let us know the results.
> Regards,
> Jayesh
> (PS: Please reply to this email for further correspondence regarding this request - I have copied the email to mpich-discuss instead of mpich2-dev since the discussion is not related to mpich2 dev )
> From: "Yessica Brinkmann" <yessica.brinkmann at gmail.com>
> To: mpich2-dev at mcs.anl.gov
> Sent: Friday, May 21, 2010 7:08:41 PM GMT -06:00 US/Canada Central
> Subject: Re: [mpich2-dev] I can not make MPI recognizes a dual core
> Very thanks for your response. I am using windows 7 and I execute at
> windows comman line mpiexec -np 2 my_program.exe that you say to me,
> at the MPICH2\bin directory.
> The system response to me:
> Please specify an authentication passphrase for smpd:
> And then I write the authentication passphrase that I write on the
> MPICH instalation and the system response to me:
> I will thanks you very much any help.
> Thanks,
> Yessica Brinkmann
> 2010/5/21 Lisandro Dalcin <dalcinl at gmail.com>:
>> On 21 May 2010 14:07, Yessica Brinkmann <yessica.brinkmann at gmail.com> wrote:
>>> Hello.
>> Hello, Yessica
>>> I am using MPICH2. I am writing my first program in MPI.
>> This mailing list is related to DEVELOPMENT of MPICH2, general (and
>> pretty basic, in your case) user-level questions about MPI should be
>> directed elsewhere.
>>> I write the sentences:
>>> int id;
>>> MPI_Comm_rank (MPI_COMM_WORLD, & id);
>>> if (id == 0)
>>> / * Master task * /
>>> else
>>> / * Worker task * /
>>> And I write other sentences. The issue is that it does not recognize a
>>> DualCore processor, and takes the machine as it only has one
>>> processor, indeed, never enters the else.
>>> I would appreciate very much any help.
>>> Sincerely,
>>> Yessica Brinkmann
>> After compiling your program:
>> $ mpicc sourcecode.c -o myprogram
>> you have to run it like this (requires first to "mpdboot"):
>> $ mpiexec -n 2 ./myprogram
>> of like this:
>> $ mpiexec.hydra -n 2 ./myprogram
>> Lisandro Dalcin
>> CIMEC (INTEC/CONICET-UNL)
>> Predio CONICET-Santa Fe
>> Colectora RN 168 Km 472, Paraje El Pozo
>> Tel: +54-342-4511594 (ext 1011)
>> Tel/Fax: +54-342-4511169
