[mpich-discuss] try to install MPICH2 on SGI under local account
Mei, Rui
rum06003 at engr.uconn.edu
Mon May 24 14:43:16 CDT 2010
Here it is. I really appreciate you and Rajeev are still trying to work out this for me. I do not know where else to search help.
Rui
From: mpich-discuss-bounces at mcs.anl.gov [mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Pavan Balaji [balaji at mcs.anl.gov]
Sent: Monday, May 24, 2010 3:40 PM
Subject: Re: [mpich-discuss] try to install MPICH2 on SGI under local account
This is bizarre. Can you send me your Makefile.in as well?
-- Pavan
On 05/24/2010 02:17 PM, Mei, Rui wrote:
> I have also tried the latest version. It's similar error message. I really have no clue now.
> Rui
> From: mpich-discuss-bounces at mcs.anl.gov [mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Rajeev Thakur [thakur at mcs.anl.gov]
> Sent: Monday, May 24, 2010 1:58 PM
> You are using MPICH2 1.1, which is an old version. Why don't you try the
> latest, 1.2.1p1.
> Rajeev
>> -----Original Message-----
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Mei, Rui
>> Sent: Monday, May 24, 2010 8:42 AM
>> under local account
>> Hi, Pavan,
>> Here are attached configure log file, make log file and
>> Makefile. And the files required for running MPI are not
>> installed, e.g.,
>> in the /u/home/rum06003/mpi/bin directory, there are only
>> three files: mpiexec.gforker mpiexec.hydra pmi_proxy.
>> Thank you very much.
>> Rui
>> Sent: Sunday, May 23, 2010 10:22 PM
>> under local account
>> It looks like some of the variables in your makefile are not set. Can
>> you send us the top-level config.log and Makefile?
>> Btw, only the documentation didn't get installed. The files
>> required for
>> running MPI applications should already be installed before
>> this error,
>> I think.
>> -- Pavan
>> On 05/23/2010 07:43 PM, Mei, Rui wrote:
>>> Hi, all,
>>> Attached is the mi.txt file for your notice. I am
>> desperately hoping to install mpi on this machine for my
>> research model.
>>> I really appreciate your help.
>>> Rui
>>> From: Mei, Rui
>>> Sent: Sunday, May 23, 2010 8:36 PM
>>> Subject: RE: [mpich-discuss] try to install MPICH2 on SGI
>> under local account
>>> Hi, Pavan,
>>> Thanks for your help. Now I can pass the configure step but
>> get stuck at the install step while I was executing
>>> 'make install 2>&1 | tee mi.txt'. Here is the error
>> message. I am looking forward to help from you or someone who can
>>> kindly offer some clues. Is it because I am under my own
>> account instead of root account?
>>> /usr/bin/install -c -m 644 MPI_Win_set_errhandler.html
>> /www3/MPI_Win_set_errhandler.html
>>> /usr/bin/install: cannot create regular file
>> `/www3/MPI_Win_set_errhandler.html': No such file or directory
>>> /usr/bin/install -c -m 644 MPI_Win_set_name.html
>> /www3/MPI_Win_set_name.html
>> `/www3/MPI_Win_set_name.html': No such file or directory
>>> /usr/bin/install -c -m 644 MPI_Win_start.html
>> /www3/MPI_Win_start.html
>> `/www3/MPI_Win_start.html': No such file or directory
>>> /usr/bin/install -c -m 644 MPI_Win_test.html /www3/MPI_Win_test.html
>> `/www3/MPI_Win_test.html': No such file or
>> directory/usr/bin/install -c -m 644 MPI_Win_unlock.html
>> /www3/MPI_Win_unlock.html
>> `/www3/MPI_Win_unlock.html': No such file or directory
>>> /usr/bin/install -c -m 644 MPI_Win_wait.html /www3/MPI_Win_wait.html
>> `/www3/MPI_Win_wait.html': No such file or
>> directory/usr/bin/install -c -m 644 MPI_Wtick.html
>> /www3/MPI_Wtick.html
>> `/www3/MPI_Wtick.html': No such file or directory
>>> /usr/bin/install -c -m 644 MPI_Wtime.html /www3/MPI_Wtime.html
>> `/www3/MPI_Wtime.html': No such file or directory
>>> make: *** [install] Error 1
>>> rum06003 at linuxAltix:~/mpich2-1.1>
>>> Rui
>>> Sent: Sunday, May 23, 2010 7:10 PM
>> under local account
>>> Rui,
>>> MPICH2's current default channel (ch3:nemesis) uses CPU atomic
>>> operations for performance issues. Since these are architecture
>>> specific, some architectures are natively supported and for
>> some others
>>> we need to emulate these atomics (which obviously loses
>> performance).
>>> The two options in such cases are:
>>> 1. Use the emulated atomic operations by specifying the
>>> --with-atomic-primitives=no option to configure.
>>> 2. Build MPICH2 with a different channel (ch3:sock) which
>> does not use
>>> these atomic operations by specifying the
>> --with-device=ch3:sock option
>>> to configure.
>>> The second option might perform a little better amongst the two, but
>>> both options will have some performance penalty compared to
>>> architectures where atomics are natively supported.
>>> -- Pavan
>>> On 05/23/2010 06:02 PM, Mei, Rui wrote:
>>>> Hi, all,
>>>> I am trying to install MPICH2-1.2.1 under my local
>> directory on SGI machine with system information"Linux
>> linuxAltix 2.6.5-7.252-sn2 #1 SMP Tue Feb 14 11:11:04 UTC
>> 2006 ia64 ia64 ia64 GNU/Linux" since I do not have the
>> adminstratior access.
>>>> Here is the last portion of message after I executed "
> ./configure --prefix=/home/you/mpich2-install 2>&1 | tee c.txt"
>>>> checking for OpenPA atomic primitive availability... no
>>>> configure: error:
>>>> The nemesis channel was selected yet no native atomic
>> primitives are
>>>> available on this platform. OpenPA can emulate atomic
>> primitives using
>>>> locks by specifying --with-atomic-primitives=no but
>> performance will be
>>>> very poor. This override should only be specified for correctness
>>>> testing purposes.
>>>> configure: error: ./configure failed for channels/nemesis
>>>> configure: error: Configure of src/mpid/ch3 failed!
>>>> rum06003 at linuxAltix:~/mpich2-1.2.1> make 2>&1 | tee m.txt
>>>> make: *** No targets specified and no makefile found. Stop.
>>>> I wish someone can help me to solve this problem here.
>>>> Rui
>>>> _______________________________________________
>>>> mpich-discuss mailing list
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>> Pavan Balaji
>>> http://www.mcs.anl.gov/~balaji
>> Pavan Balaji
Pavan Balaji
Desc: Makefile.in
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100524/84c9f544/attachment-0001.obj>
