[mpich-discuss] Anyone with experience setting up a ring on Win 7?
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Tue May 18 15:53:44 CDT 2010
 The SMPD process manager does not setup a ring like mpd. So there is no need (way) to setup a ring with SMPD (the only process manager supported on windows - for now).
 Did you try turning off any firewall running on the machines ? Can you try running "smpd -status MACHINE2_NAME" from a command prompt MACHINE1 (MACHINE1 - Where you run wmpiconfigure) ?
 Meanwhile, note that you cannot run MPI jobs across 32-bit and 64-bit windows machines with MPICH2.
Jayesh
----- Original Message -----
Sent: Tuesday, May 18, 2010 3:26:44 PM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] Anyone with experience setting up a ring on Win 7?
I'm trying to set up on Native Windows 7, x64.  I've got the 1.2.1p1 x64 version installed in Program Files, and because I was trying to use WMPIREGISTER and WMPICONFIG to make life easier, I have 1.2.1p1 (IA32) installed in Program Files (x86) so I can use those two utilities.  Can the Win32 utilities see the x64 smpd running on the other hosts?  I'm beginning to think perhaps not.  What happens when I run WMPICONFIGURE is that it says it can never see a host with smpd running, but there are.  It's either that or I've got some kind of software configuration issue, because I can see and transfer files and share folders between the boxes, but I can't get the "hosts" and the list of hosts to acknowledge they can see each other.  It just times out.  Just looking for ideas to help debug, and I've kind of gone dry on ideas of what to try next to narrow down the problem.
-----Original Message-----
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Jayesh Krishna
Sent: Tuesday, May 18, 2010 2:11 PM
 Are you trying to set up an mpd ring with MPICH2 on cygwin+windows 7 ? We would be able to help you if you provide us more details (Pls provide as much details as possible).
Jayesh
Sent: Tuesday, May 18, 2010 1:57:22 PM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] Anyone with experience setting up a ring on Win 7?
mpich-discuss mailing list
