[mpich-discuss] make fails with undefined reference	VALGRIND_CHECK_MEM_IS_ADDRESSABLE
    Dave Goodell
    goodell at mcs.anl.gov
    Tue May 18 10:51:39 CDT 2010
What version of valgrind do you have installed?
I suspect that your version of valgrind is older than anything that we've tested with and is slipping between the gap of "is valgrind.h available" and "does valgrind.h work".  I can strengthen the configure test if I have an idea of what version of valgrind you have.
In the interim, the best workaround for you is probably to either remove "meminit" from your "--enable-g" arg, hack up the configure tests for valgrind so that they always fail, or delete lines 25-35 of "src/include/mpiu_valgrind.h".
-Dave
On May 18, 2010, at 10:38 AM, Wei-keng Liao wrote:
> When running make of mpich2-1.2.1p1, I got an error complaining undefined reference to VALGRIND_CHECK_MEM_IS_ADDRESSABLE. Please see the attached standard outputs from configure and make.
> The configure command and environment variables used are also given in out.configure file.
> I am using GNU compilers, gcc and gfortran, to build MPICH2.
> gcc version 4.0.2 20051125 (Red Hat 4.0.2-8)
> % rpm -q glibc
> glibc-2.3.6-3
> % uname -a
> Linux 2.6.17-1.2142_FC4smp #1 SMP Tue Jul 11 22:57:02 EDT 2006 i686 athlon i386 GNU/Linux
> Wei-keng
> <out.configure><out.make>
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
