[mpich-discuss] Asking for help on MPI derived data type
Jilong Yin yinjilong at gmail.com
Thu May 6 23:18:50 CDT 2010
Hello,
  I am trying to define MPI derived data type to simplify my program.
  But I can not get it working properly.
  First I describe the basic thing about the following test program.
  There are many layers consisting by many nodes. Each node has a
position(x,y,z) ( real data type )and a bound condition  type description in
(x,y,z) direction( integer data) .
  I want to send i-th layer node data in a so-called buffer space to j-th
layer node in a so-called computation space.
  I first define two MPI derived data types to describing node layer data.
And then using the new data type to exchange data between the two space.
  The following is my FORTRAN code, though it can be compiled and run , the
result is wrong.
  Can anyone help me  out?
  Thank you .
JILONG YIN
 2010-05-07
[CODE]
C The following program is used to test MPI derived data type in parallel
finite element program
C The node data in buffer space will be send to computation space
      PROGRAM TEST
    IMPLICIT NONE
    INCLUDE 'MPIF.H'
C The number of nodes on a crossection
      INTEGER,PARAMETER::N_NOD_CROSEC=10
C The number of nodes along the longitude direction
    INTEGER,PARAMETER::N_NOD_STREAM=13
C The number of total nodes
    INTEGER,PARAMETER::N_NOD=N_NOD_CROSEC*N_NOD_STREAM
C Derived data type for node layer data buffer space
    INTEGER NOD_LAY_DATA_BF(N_NOD_STREAM)
C The node position data  in buffer space
    DOUBLE PRECISION POSITION_BF(3,N_NOD)
C The node boundary condition type data in buffer space
    INTEGER IFLAG_BD_COND_BF(3,N_NOD)
C Derived data type for node layer data computation space
    INTEGER NOD_LAY_DATA(N_NOD_STREAM)
C The node position data  in computation space
    DOUBLE PRECISION POSITION(3,N_NOD)
C The node boundary condition type data in computation space
    INTEGER IFLAG_BD_COND(3,N_NOD)
C Some varibles for defining MPI derived data type
    INTEGER IBLOCK(99),IDISP(99),ITYPE(99)
    INTEGER NBLOCK
C Node data type(for buffer space and computation space)
      INTEGER NOD_LAY_DATA_BF_TYPE
      INTEGER NOD_LAY_DATA_TYPE
C MPI function status return
    INTEGER::ISTATUS(MPI_STATUS_SIZE),IERR
C My rank
    INTEGER MYID
C source rank and destination rank ID
    INTEGER ID_SRC,ID_DEST
C node layer number for sending and receiving
    INTEGER ISNS,IRNS
    INTEGER I,J,NOD1,NOD2
C Initilize the MPI enviroment
    CALL MPI_INIT(IERR)
C Get the rank ID
      CALL MPI_COMM_RANK(MPI_COMM_WORLD,MYID,IERR)
C----------------------------------------------------------
C Define node layer derived data type for buffer space
      NBLOCK=0
      NBLOCK=NBLOCK+1
    IBLOCK(NBLOCK)=1
    ITYPE(NBLOCK)=MPI_INTEGER
    CALL MPI_ADDRESS(NOD_LAY_DATA_BF,IDISP(NBLOCK),IERR)
C Node position
      NBLOCK=NBLOCK+1
    IBLOCK(NBLOCK)=3*N_NOD_CROSEC
    ITYPE(NBLOCK)=MPI_DOUBLE_PRECISION
    CALL MPI_ADDRESS(POSITION_BF,IDISP(NBLOCK),IERR)
C Node boundary condition type
      NBLOCK=NBLOCK+1
    CALL MPI_ADDRESS(IFLAG_BD_COND_BF,IDISP(NBLOCK),IERR)
C convert to relative address
    DO I=NBLOCK,1,-1
      IDISP(I)=IDISP(I)-IDISP(1)
    END DO
C generate new derived data type
    CALL MPI_TYPE_STRUCT(NBLOCK,IBLOCK,IDISP,ITYPE,
     &                     NOD_LAY_DATA_BF_TYPE,IERR)
      CALL MPI_TYPE_COMMIT(NOD_LAY_DATA_BF_TYPE,IERR)
C Define node layer derived data type for computation space
C
      NBLOCK=0
      NBLOCK=NBLOCK+1
    IBLOCK(NBLOCK)=1
    CALL MPI_ADDRESS(NOD_LAY_DATA,IDISP(NBLOCK),IERR)
C Node position
      NBLOCK=NBLOCK+1
    CALL MPI_ADDRESS(POSITION,IDISP(NBLOCK),IERR)
      NBLOCK=NBLOCK+1
    CALL MPI_ADDRESS(IFLAG_BD_COND(1,1),IDISP(NBLOCK),IERR)
    DO I=NBLOCK,1,-1
    END DO
     &                     NOD_LAY_DATA_TYPE,IERR)
      CALL MPI_TYPE_COMMIT(NOD_LAY_DATA_TYPE,IERR)
CC---------------------------------------------------------
C Node data initilize for computation space
      NOD_LAY_DATA(:)=0
    POSITION(:,:)=0.0D0
    IFLAG_BD_COND(:,:)=-1
C Prepare test data for buffer space
      DO I=1,N_NOD_STREAM
      NOD_LAY_DATA_BF(I)=I
    END DO
      DO I=1,N_NOD
      DO J=1,3
        POSITION_BF(J,I)=J+I*10.0D0
          IFLAG_BD_COND_BF(J,I)=J+I*10+90000000
      END DO
    END DO
C I will send the ISNS-th layer node data in buffer space to IRNS-th layer
node data in computation space
    ISNS=1
    IRNS=2
C This is the source rank id and destination rank id
    ID_SRC=0
    ID_DEST=1
C send node layer data using derived data type 1
    IF(MYID.EQ.ID_SRC) THEN
        CALL MPI_SEND(NOD_LAY_DATA_BF(ISNS),1,NOD_LAY_DATA_BF_TYPE,
     &                ID_DEST,123,MPI_COMM_WORLD,IERR)
    END IF
C receive node layer data using derived data type 2
    IF(MYID.EQ.ID_DEST) THEN
          CALL MPI_RECV(NOD_LAY_DATA(IRNS),1,NOD_LAY_DATA_TYPE,
     &                  ID_SRC,123,MPI_COMM_WORLD,ISTATUS,IERR)
    END IF
    print*,'Myid=',MYID,'IERR=',ierr
C output the received data to verify them
    PRINT*,ID_SRC,NOD_LAY_DATA_BF(ISNS),
     &       ID_DEST,NOD_LAY_DATA(IRNS)
    DO I=1,N_NOD_CROSEC
      NOD1=I+(ISNS-1)*N_NOD_CROSEC
      NOD2=I+(IRNS-1)*N_NOD_CROSEC
      PRINT*,NOD1,POSITION_BF(1,NOD1),NOD2,POSITION(1,NOD2)
      PRINT*,NOD1,POSITION_BF(2,NOD1),NOD2,POSITION(2,NOD2)
      PRINT*,NOD1,POSITION_BF(3,NOD1),NOD2,POSITION(3,NOD2)
    PRINT*,NOD1,IFLAG_BD_COND_BF(1,NOD1),NOD2,IFLAG_BD_COND(1,NOD2)
    PRINT*,NOD1,IFLAG_BD_COND_BF(2,NOD1),NOD2,IFLAG_BD_COND(2,NOD2)
    PRINT*,NOD1,IFLAG_BD_COND_BF(3,NOD1),NOD2,IFLAG_BD_COND(3,NOD2)
    END DO
    END IF
c
      CALL MPI_TYPE_FREE(NOD_LAY_DATA_BF_TYPE,IERR)
      CALL MPI_TYPE_FREE(NOD_LAY_DATA_TYPE,IERR)
    CALL MPI_FINALIZE(IERR)
    END
[/CODE]
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100507/9604b1a6/attachment.htm>
