[mpich-discuss] Problems with Pcontrol and MPE2 -- fixed, please accept this patch
Anthony Chan chan at mcs.anl.gov
Sun May 2 00:44:51 CDT 2010
Hi Brian,
Can you try log_mpi_core.c again ?
https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/src/mpe2/src/wrappers/src/log_mpi_core.c
You may also need the update in slog2sdk, i.e. jumpshot and clog2TOslog2 code.
https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/src/mpe2/src/slog2sdk/lib/jumpshot.jar
https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/src/mpe2/src/slog2sdk/lib/clog2TOslog2.jar
A.Chan
----- "Anthony Chan" <chan at mcs.anl.gov> wrote:
> Great.  I will look into the bug with your test program.
> Thanks,
> A.Chan
> ----- "Brian Wainscott" <brian at lstc.com> wrote:
> > Hi Anthony,
> > OK, I've created a short program that does this:
> >  1 -- creates and dups some communicators
> >  2 -- frees some of them
> >  3 -- uses some of them, then frees them.
> > It can be compiled without any calls to MPI_Pcontrol, in which case
> it
> > runs fine
> > and produces a log file.  It can also be compiled with calls to
> > MPI_Pcontrol(0)
> > just before (1) and a call to MPI_Pcontrol(1) between (2) and (3).
> > (see
> > WITH_PCONTROL at the top of the source file).
> > If I build it with the MPI_Pcontrol calls in place, it segfaults
> with
> > your latest
> > changes.  Hopefully this will help you figure out what is going on.
> > I'm using OpenMPI with MPE2, but I really don't think that matters.
> I
> > built it
> > with this command:
> > mpecc -mpilog -o dynasim dynasim.c
> > and ran it on 4 processors.
> > Good luck, and let me know what you find out.
> > Brian
