[mpich-discuss] How to run MPI application in WinXP32
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Wed Mar 31 09:06:08 CDT 2010
 The error message shows that you have entered/registered an incorrect password for the username.
 Have you registered the username with MPICH2 ? You can register a username using the "-register" option of the mpiexec command (Type "mpiexec -register" at the command prompt).  You can validate that the username/password is registered correctly using the "-validate" option of the mpiexec command.
 I would also recommend trying to create a username without spaces(eg: "ChauDinhThanh") and see if it works.
 Let us know the results.
Jayesh
----- Original Message -----
Sent: Wednesday, March 31, 2010 2:44:07 AM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] How to run MPI application in WinXP32
Dear:
I am studying MPI programming by myself. I use winXP32. The computer name is saigon. And user name of winxp is Chau Dinh Thanh.
Here I am running MPI application on single computer. When I try to run an MPI application by mpiexec wrapper I got this error
Credentials for Chau Dinh Thanh rejected connecting to saigon
Aborting: Unable to connect to saigon
Can you please help me to manage thi error?
Thanks
Chau Dinh Thanh
mpich-discuss mailing list
