[mpich-discuss] MPICH 2 install
    Rajeev Thakur
    thakur at mcs.anl.gov
    Tue Mar 30 07:58:05 CDT 2010
Your build seems to have completed fine. Can you run the example cpi
program?
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of roman v.
> Sent: Tuesday, March 30, 2010 4:33 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] MPICH 2 install
> Using the default ch3:nemesis device did not resolve the problem.
> I am attaching the new relevant files and what I did is below.
> Please help.  Thanks
> /home/iomega15/libraries/mpich2-1.2.1p1/configure
>  -prefix=/home/iomega15/mpich2-install  2>&1 | tee c.txt
> make 2>&1 | tee m.txt
> make 2>&1 | tee mi.txt
> export PATH=/home/iomega15/mpich2-install/bin:$PATH
> [iomega15 at cluster mpich2-install]$ pwd
> [iomega15 at cluster mpich2-install]$ ls
> include  lib  share
> ~Roman
> 2010/3/29 Rajeev Thakur <thakur at mcs.anl.gov>:
> > Why don't you just use the defaut ch3:nemesis device. It
> uses shared
> > memory for communication within a node. ch3:shm is old and
> no longer
> > supported.
> > Rajeev
> >> Sent: Monday, March 29, 2010 7:30 PM
> >> Subject: [mpich-discuss] MPICH 2 install
> >> Hi,
> >> I am trying to install MPICH2 with a shared memory configuration.
> >> 1) I am getting some warnings at compile time "configure: WARNING:
> >> unrecognized options: --with-device"
> >> 2) I do not have a bin folder after the compilation process
> >> I am attaching the relevant files and what I did is below.
> >> Please help.  Thanks
> >> -prefix=/home/iomega15/mpich2-install --with-device=ch3:shm 2>&1 |
> >> tee c.txt
> >> [iomega15 at cluster mpich2-install]$ ls include  lib  share
> >> Sincerely,
> >> Roman Voronov
> >> Chemical Engineering PhD Candidate
> >> ChE Graduate Senator 2005-2006
> >> Founder of the RUssian Speaking Student Association (RUSSA) - A
> >> Registered Student Organization of the University of Oklahoma
> >> (405) 796-4087 http://www.ou.edu/russa
> > _______________________________________________
> > mpich-discuss mailing list
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Sincerely,
> Roman Voronov
