[mpich-discuss] configuring mpich 2 on Mac OS 10.6
    Rajeev Thakur
    thakur at mcs.anl.gov
    Fri Mar 26 16:00:00 CDT 2010
You can also try setting the env variable FFLAGS to -m64 before running
configure.
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Pavan Balaji
> Sent: Friday, March 26, 2010 3:28 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] configuring mpich 2 on Mac OS 10.6
> Ok, this showed up a bunch of times, so I have added a FAQ
> entry for it.
> Please see:
> http://wiki.mcs.anl.gov/mpich2/index.php/Frequently_Asked_Ques
> tions#Q:_I_get_a_configure_error_saying_.22Incompatible_Fortra
n_and_C_Object_File_Types.21.22
> Thanks,
>   -- Pavan
> Brandt Belson wrote:
> > Hello,
> > I'm trying to configure (then install) mpich 2 on a Mac OS
> 10.6, and I'm
> > having a problem. ./configure, without any additional
> options, fails.
> > This is probably an easy fix but I don't know what it is.
> I'm pasting
> > the entire output of configure below.
> > rainier:mpich2-1.2.1p1 bbelson$ ./configure
> > Configuring MPICH2 version 1.2.1p1
> > Running on system: Darwin rainier 10.2.0 Darwin Kernel
> Version 10.2.0:
> > Tue Nov  3 10:37:10 PST 2009; root:xnu-1486.2.11~1/RELEASE_I386 i386
> > Executing mpich2prereq in
> > /home/bbelson/Downloads/mpich2-1.2.1p1/src/mpid/ch3 with
> > /home/bbelson/Downloads/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis
> > sourcing
> /home/bbelson/Downloads/mpich2-1.2.1p1/src/pm/mpd/mpich2prereq
> > sourcing
> /home/bbelson/Downloads/mpich2-1.2.1p1/src/pm/hydra/mpich2prereq
> > sourcing
> /home/bbelson/Downloads/mpich2-1.2.1p1/src/pm/gforker/mpich2prereq
> > sourcing /home/bbelson/Downloads/mpich2-1.2.1p1/src/pm/mpd/setup_pm
> > checking for gcc... gcc
> > checking for C compiler default output file name... a.out
> > checking whether the C compiler works... yes
> > checking whether we are cross compiling... no
> > checking for suffix of executables...
> > checking for suffix of object files... o
> > checking whether we are using the GNU C compiler... yes
> > checking whether gcc accepts -g... yes
> > checking for gcc option to accept ISO C89... none needed
> > checking how to run the C preprocessor... gcc -E
> > checking whether the compiler defines __func__... yes
> > checking whether the compiler defines __FUNC__... no
> > checking whether the compiler sets __FUNCTION__... yes
> > checking whether C compiler accepts option -O2... yes
> > checking whether routines compiled with -O2 can be linked with ones
> > compiled without -O2... yes
> > checking for type of weak symbol alias support... no
> > checking whether __attribute__ ((weak)) allowed... yes
> > checking whether __attribute ((weak_import)) allowed... yes
> > checking for g77... no
> > checking for xlf... no
> > checking for f77... no
> > checking for frt... no
> > checking for pgf77... no
> > checking for cf77... no
> > checking for fort77... no
> > checking for fl32... no
> > checking for af77... no
> > checking for xlf90... no
> > checking for f90... no
> > checking for pgf90... no
> > checking for pghpf... no
> > checking for epcf90... no
> > checking for gfortran... gfortran
> > checking whether we are using the GNU Fortran 77 compiler... yes
> > checking whether gfortran accepts -g... yes
> > checking whether Fortran 77 compiler accepts option -O2... yes
> > checking how to get verbose linking output from gfortran... -v
> > checking for Fortran 77 libraries of gfortran...
> >  -L/usr/local/gfortran/lib/gcc/i386-apple-darwin8.10.1/4.5.0
> -L/usr/local/gfortran/lib/gcc/i386-apple-darwin8.10.1/4.5.0/../../..
> > -lgfortran
> > checking whether gfortran accepts the FLIBS found by autoconf... yes
> > checking whether C can link with
> > -lgfortran... yes
> > checking for linker for Fortran main programs... Use
> Fortran to link
> > programs
> > checking whether Fortran 77 and C objects are compatible... no
> > checking for file... file
> > configure: error: ****  Incompatible Fortran and C Object
> File Types!  ****
> > F77 Object File Type produced by "gfortran  -O2" is : :
> Mach-O object i386.
> >  C  Object File Type produced by "gcc  -O2" is : : Mach-O
> 64-bit object
> > x86_64.
> > Any help is appreciated, thank you!
> > Brandt
> > _______________________________________________
> > mpich-discuss mailing list
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
