[mpich-discuss] MPICH with PGI compilers (Assertion failed in helper_fns.c)
Sarat Sreepathi
sarat_s at ncsu.edu
Wed Mar 24 14:42:56 CDT 2010
Dave,
Thanks for your suggestions. I tracked down the problem to a
MPI_Scatterv call where the source and destination buffers overlap.
I guess we never noticed this issue as this check may not have been
enforced until recently.
I modified the call to use MPI_IN_PLACE for the root process and it worked.
Posting to the list for the benefit of others who might encounter this.
Earlier:
MPI_Scatterv(sources,recvCount,displs, MPI_INT, sources, localTrials,
MPI_INT, 0, MPI_COMM_WORLD);
Updated:
MPI_Scatterv(sources,recvCount,displs, MPI_INT, (rank) ? sources :
MPI_IN_PLACE , localTrials, MPI_INT, 0, MPI_COMM_WORLD);
Sarat.
On 03/24/2010 10:59 AM, Dave Goodell wrote:
> This has come up before:
> https://lists.mcs.anl.gov/mailman/htdig/mpich-discuss/2010-March/006658.html
> and
> https://trac.mcs.anl.gov/projects/mpich2/ticket/1006
> In the first case there is probably a real bug, but we never received
> enough information from the poster to reproduce it for ourselves. The
> good news for that one is that the workaround of CPPFLAGS="-DNDEBUG"
> did work for him. The second case was a combination of user error and
> poor error messages/behavior.
> Do you have a small test case that I can use to reproduce the problem?
> The change you mentioned (r6344) would help us track this problem
> down, but it unfortunately isn't present in mpich2-1.2.1p1.
> -Dave
> On Mar 24, 2010, at 12:59 AM, Sarat Sreepathi wrote:
>> Hello:
>> We recently installed new PGI compilers(10.2-1 64-bit) and built
>> MPICH(1.2.1p1) with the new compilers on our Opteron cluster. Initial
>> tests revealed no problems.
>> But when I built and ran a parallel program today, it crashed with an
>> assertion failure in the MPI source. (src/mpi/coll/helper_fns.c):
>> memcpy argument memory ranges overlap
>> The detailed error and configuration details are enclosed below.
>> I found a recent changeset that's related to this:
>> http://trac.mcs.anl.gov/projects/mpich2/changeset/6344#file2
>> Your help is greatly appreciated in resolving the issue.
>> Thanks,
>> Sarat.
>> $> mpirun -n 1 ./epanetmsx input0.txt output0.txt
>> Assertion failed in file helper_fns.c at line 337: 0
>> memcpy argument memory ranges overlap, dst_=0x633440 src_=0x633440
>> len_=16
>> internal ABORT - process 0
>> rank 0 in job 33695 master_4268 caused collective abort of all ranks
>> exit status of rank 0: return code 1
>> Excerpt from src/mpi/coll/helper_fns.c
>> 333 if (sendtype_iscontig && recvtype_iscontig)
>> 334 {
>> 335 MPIU_Memcpy(((char *) recvbuf + recvtype_true_lb),
>> 336 ((char *) sendbuf + sendtype_true_lb),
>> 337 copy_sz);
>> 338 }
>> The cluster is running an older OS: SuSE 10.
>> $ uname -a
>> Linux master 2.6.14-ck5-suse10-osmp #55 SMP Tue Jan 3 13:19:36 EST
>> 2006 x86_64 x86_64 x86_64 GNU/Linux
>> >$ mpich2version
>> MPICH2 Version: 1.2.1p1
>> MPICH2 Release date: Unknown, built on Sun Mar 7 21:16:25 EST 2010
>> MPICH2 Device: ch3:nemesis
>> MPICH2 configure: --prefix=/usr/local/mpich2-1.2.1 --enable-f77
>> --enable-f90 --enable-cxx
>> MPICH2 CC: pgcc -O2
>> MPICH2 CXX: pgCC -O2
>> MPICH2 F77: pgf77
>> MPICH2 F90: pgf90
>> Sarat Sreepathi
>> Doctoral Student
>> Dept. of Computer Science
>> North Carolina State University
>> sarat_s at ncsu.edu ~ (919)645-7775
>> http://www.sarats.com
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Sarat Sreepathi
Doctoral Student
