[mpich-discuss] Regarding MPICH2-1.1.1p1 testing basing on open-mx
Darius Buntinas
buntinas at mcs.anl.gov
Fri Mar 19 17:14:55 CDT 2010
Can you try using tcp (don't specify --with-device) and see if you have
the same problem?
-d
On 03/19/2010 03:31 AM, 李俊丽 wrote:
> Hello,
> Just do:
> ./configure --with-device=ch3:nemesis:mx --with-mx-lib=/opt/open-mx/lib/
> --with-mx-include=/opt/open-mx/include/
> make
> make install
> Then, I start open-omx service, and test mpich2 based on open-mx.
> [root at cu02 ~]# mpiexec -n 4 /usr/lib64/mpich2/bin/mpitests-IMB-EXT
> Unidir_Get
> It has this error message:
> rank 0 in job 8 cu02.hpc.com_54277 caused collective abort of all ranks
> exit status of rank 0: killed by signal 9
> And the same wrong comes with "mpiexec -n 4
> /usr/lib64/mpich2/bin/mpitests-IMB-EXT Bidir_Get "
> Is there any way to solve this problem?
> Thanks!
> Regards
> Lily
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
