[mpich-discuss] Regarding MPICH2-1.1.1p1 testing basing on	open-mx
    Dave Goodell
    goodell at mcs.anl.gov
    Fri Mar 19 13:22:45 CDT 2010
 From the names they do look like MPI one-sided tests, but I don't
have a copy of the IMB benchmarks handy.  As I recall the
ch3:nemesis:mx netmod does support the MPI one-sided APIs, although
it's probably implemented in terms of two-sided operations under the
hood.  Guillaume would know for sure.
-Dave
On Mar 19, 2010, at 1:08 PM, Scott Atchley wrote:
> Dave,
> Are these one-sided tests? Does Nemesis/MX support one-sided?
> Scott
> On Mar 19, 2010, at 1:59 PM, Brice Goglin wrote:
>> Some bugs were reported in the past about some MPICH2 tests not
>> working,
>> but we never reproduced them with recent MPICH2 and Open-MX versions.
>> I'd like to know what kind of interfaces, hosts and kernels were used
>> here. And also how many processes per node were used.
>> Brice
>> Dave Goodell wrote:
>>> I don't think that we have tested OpenMX with the mx netmod, so I'm
>>> not sure if there are any bugs there.  I've CCed the primary
>>> developers of both OpenMX and our mx netmod in case they have any
>>> information on this.
>>> Do simpler tests work?  The "examples/cpi" program in your MPICH2
>>> build directory is a good simple sanity test.
>>> -Dave
>>> On Mar 19, 2010, at 3:31 AM, 李俊丽 wrote:
>>>> Hello,
>>>> Just do:
>>>> ./configure  --with-device=ch3:nemesis:mx
>>>> --with-mx-lib=/opt/open-mx/lib/ --with-mx-include=/opt/open-mx/
>>>> include/
>>>> make
>>>> make install
>>>> Then, I start open-omx service, and test mpich2 based on open-mx.
>>>> [root at cu02 ~]# mpiexec -n 4 /usr/lib64/mpich2/bin/mpitests-IMB-EXT
>>>> Unidir_Get
>>>> It has this error message:
>>>> rank 0 in job 8 cu02.hpc.com_54277 caused collective abort of all
>>>> ranks exit status of rank 0: killed by signal 9
>>>> And the same wrong comes with "mpiexec -n 4
>>>> /usr/lib64/mpich2/bin/mpitests-IMB-EXT Bidir_Get "
>>>> Is there any way to solve this problem?
>>>> Thanks!
>>>> Regards
>>>> Lily
>>>> _______________________________________________
>>>> mpich-discuss mailing list
>>>> mpich-discuss at mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
