[mpich-discuss] Setting TCP buffer size ( P4_SOCKBUFSIZE ) in Windoze?
Rahul Mukerjee r.mukerjee at gmail.com
Thu Mar 18 16:49:33 CDT 2010
I found out recently that increasing  the value of the parameter
P4_SOCKBUFSIZE to the maximum level allowed improves throughput
significantly (Ref: Protocol Dependent Message-Passing Performance on Linux
Clusters; Dave Turner and Xuehua Chen). Is there a way to achieve the same
result in Windoze XP / Vista?
Also, suppose I have a 10 integer / double precision arrays (each of
dimension, say, 100000) on CPU1. If I were to send this data to CPU0, which
would be faster:
1. Sending + receiving data from the 10 arrays one array at a time, OR,
2. Combining the data into one single array (dimension = 10 X 100000) and
then sending / receiving it?
Is this a general result?
Thanks.
Rahul.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100318/fb7119d1/attachment.htm>
