[mpich-discuss] clean up after MPI_Cart_create
burlen
burlen.loring at gmail.com
Thu Mar 18 10:20:55 CDT 2010
I tried it, but it crashes, some info below. The program is in fortran.
The first member of the user defined type c is the comm.
0-1: (gdb) p c
0: $1 = ( -2080374780, (.TRUE., .TRUE., .TRUE.), .TRUE., 2, (2, 1, 0),
(0, 0, 0), 2, ( (1, 512, 1, 512, 1, 512) ), ( (1, 512, 1, 256, 1, 512) ) )
1: $1 = ( -2080374782, (.TRUE., .TRUE., .TRUE.), .TRUE., 2, (2, 1, 0),
(1, 0, 0), 2, ( (1, 512, 1, 512, 1, 512) ), ( (1, 512, 257, 512, 1, 512) ) )
0-1: (gdb) n
0-1: 79 call MPI_Comm_free(c%Comm)
0-1: (gdb) n
0-1:
0-1: Program received signal SIGSEGV, Segmentation fault.
0-1: 0x00007ffff78080d9 in pmpi_comm_free_ (v1=<value optimized out>,
ierr=0x0)
0-1: at comm_freef.c:190
0-1: 190 *ierr = MPI_Comm_free( (MPI_Comm *)(v1) );
Rajeev Thakur wrote:
> Did you do a Comm_free?
> Rajeev
>> -----Original Message-----
>> From: mpich-discuss-bounces at mcs.anl.gov
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of burlen
>> Sent: Thursday, March 18, 2010 5:50 AM
>> To: mpich-discuss at mcs.anl.gov
>> Subject: [mpich-discuss] clean up after MPI_Cart_create
>> Is there a way to clean up after MPI_Cart_create ? Other wise
>> it leaks some resources and pollutes valgrind output.
>> Thanks
>> Burlen
>> ==22729== Memcheck, a memory error
>> detector
>> ==22729== Copyright (C) 2002-2009, and GNU GPL'd, by Julian Seward et
>> al.
>> ==22729== Using Valgrind-3.5.0-Debian and LibVEX; rerun with -h for
>> copyright info
>> ==22729== Command:
>> ./TestSubArrayWriter
>> ==22729==
>> leaked context IDs detected: mask=0x54b31a0
>> mask[0]=0x7fffffff
>> In direct memory block for handle type ATTR, 1 handles are still
>> allocated
>> In direct memory block for handle type KEYVAL, 1 handles are still
>> allocated
>> In direct memory block for handle type COMM, 1 handles are still
>> allocated
>> [0] 8 at [0x0000000006416bf8],
>> cart_create.c[154]
>> [0] 8 at [0x0000000006416b08],
>> cart_create.c[152]
>> [0] 8 at [0x0000000006416a18],
>> cart_create.c[150]
>> [0] 56 at [0x00000000064168f8],
>> cart_create.c[144]
>> [0] 8 at [0x0000000006416538],
>> local_proc.c[91]
>> [0] 8 at [0x0000000006416448],
>> local_proc.c[90]
>> [0] 24 at [0x0000000006416168],
>> mpid_vc.c[79]
>> ==22729==
>> ==22729== HEAP SUMMARY:
>> ==22729== in use at exit: 1,240 bytes in 7 blocks
>> ==22729== total heap usage: 164 allocs, 149 frees, 8,509,866 bytes
>> allocated
>> ==22729==
>> ==22729== 168 bytes in 1 blocks are definitely lost in loss
>> record 4 of 7
>> ==22729== at 0x4C25153: malloc (vg_replace_malloc.c:195)
>> ==22729== by 0x521C386: MPIU_trmalloc (trmem.c:230)
>> ==22729== by 0x517DD14: MPIU_Find_local_and_external
>> (local_proc.c:90)
>> ==22729== by 0x511FAE1: MPIR_Comm_commit (commutil.c:228)
>> ==22729== by 0x511E31B: PMPI_Comm_split (comm_split.c:384)
>> ==22729== by 0x50C06BA: MPIR_Cart_create (cart_create.c:119)
>> ==22729== by 0x50C1A8F: PMPI_Cart_create (cart_create.c:298)
>> ==22729== by 0x50C1E7C: MPI_CART_CREATE (cart_createf.c:199)
>> ==22729== by 0x402EC4:
>> __cartesiandecompmodule_MOD_createcommunicator
>> (CartesianDecompModule.f90:194)
>> ==22729== by 0x40325A:
>> __cartesiandecompmodule_MOD_initializecartesiandecomp_u
>> (CartesianDecompModule.f90:66)
>> ==22729== by 0x40190D: MAIN__ (TestSubArrayWriter.f90:76)
>> ==22729== by 0x403369: main (in
>> /home/burlen/ext/MPI-IO/TestSubArrayWriter)
>> ==22729==
>> record 5 of 7
>> ==22729== by 0x517DD47: MPIU_Find_local_and_external
>> (local_proc.c:91)
>> ==22729==
>> ==22729== 184 bytes in 1 blocks are definitely lost in loss
>> record 6 of 7
>> ==22729== by 0x51A9D59: MPID_VCRT_Create (mpid_vc.c:79)
>> ==22729== by 0x511E135: PMPI_Comm_split (comm_split.c:365)
>> ==22729==
>> ==22729== 552 (216 direct, 336 indirect) bytes in 1 blocks
>> are definitely lost in loss record 7 of 7
>> ==22729== by 0x50C07A0: MPIR_Cart_create (cart_create.c:143)
>> ==22729==
>> ==22729== LEAK SUMMARY:
>> ==22729== definitely lost: 736 bytes in 4 blocks
>> ==22729== indirectly lost: 336 bytes in 2 blocks
>> ==22729== possibly lost: 0 bytes in 0 blocks
>> ==22729== still reachable: 168 bytes in 1 blocks
>> ==22729== suppressed: 0 bytes in 0 blocks
>> ==22729== Reachable blocks (those to which a pointer was
>> found) are not shown.
>> ==22729== To see them, rerun with: --leak-check=full
>> --show-reachable=yes ==22729== ==22729== For counts of
>> detected and suppressed errors, rerun with: -v ==22729==
>> ERROR SUMMARY: 4 errors from 4 contexts (suppressed: 4 from 4)
>> mpich-discuss mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
