[mpich-discuss] open failed for root's mpd conf
    Dave Goodell
    goodell at mcs.anl.gov
    Wed Mar 17 15:46:01 CDT 2010
Just to be sure, you are trying to to use a root-started mpd ring as a
regular user, correct?  If so, make sure that you have a mode 600 file
named "/etc/mpd.conf" (no leading ".") containing the secret word.
If you are trying to use a regular user-started mpd ring as a regular
user, then remove "MPD_USE_ROOT_MPD=yes" from your "~/.mpd.conf".
-Dave
On Mar 17, 2010, at 3:33 PM, rcx11 at yahoo.com wrote:
> It's "MPD_USE_ROOT_MPD=yes" as per setup guide in the link given.
> --- On Wed, 3/17/10, Dave Goodell <goodell at mcs.anl.gov> wrote:
>> From: Dave Goodell <goodell at mcs.anl.gov>
>> Subject: Re: [mpich-discuss] open failed for root's mpd conf
>> To: mpich-discuss at mcs.anl.gov
>> Date: Wednesday, March 17, 2010, 3:02 PM
>> On Mar 17, 2010, at 2:50 PM, rcx11 at yahoo.com
>> wrote:
>>> I've been searching through documentation trying to
>> find why I'm getting the error when trying to run as a
>> non-root user. I'm running Fedora 12 x86 and have installed
>> MPICH2 via yum. I've got my mpd.conf files created according
>> to http://debianclusters.cs.uni.edu/index.php/MPICH_without_Torque_Functionality
>> When trying to run mpiexec as a non-root user, I get the
>> error "/usr/bin/mpdroot: open failed for root's mpd conf
>> filempiexec_sebastian.ags-rolla.zapto.org (__init__ 1208):
>> forked process failed; status=255" What is causing this?
>> Please see section 5.1.6 of the Installer's Guide: http://www.mcs.anl.gov/research/projects/mpich2/documentation/files/mpich2-1.2.1-installguide.pdf
>> Do you have "MPD_USE_ROOT_MPD=1" set somewhere in your
>> environment or mpd.conf file?
>> -Dave
>> mpich-discuss mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
