[mpich-discuss] MPI I/O SLOW- possible	conflictingwithcommunication....code stuck for ever during IO
    Bruce Wu
    anigiss at gmail.com
    Mon Mar 15 02:09:53 CDT 2010
Sorry, I don't know what do you mean?
Do you have  error mail?
  ----- Original Message -----
  Sent: Monday, March 15, 2010 1:30 PM
  Subject: Re: [mpich-discuss] MPI I/O SLOW- possible conflictingwithcommunication....code stuck for ever during IO
  Can you send us a small test program that fails?
    From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of hossam
    Sent: Sunday, March 14, 2010 1:57 PM
    Subject: [mpich-discuss] MPI I/O SLOW- possible conflicting withcommunication....code stuck for ever during IO
    I think i have a well defined problem i wonder if someone can give an advice.
    I am running an MPI code (MPICH2) on a linux cluster.
    When i run the code with no IO inside the main runtime loop. It works perfectly fine on any number of processors and nodes. When i start dumping data during the loop
    the code get stuck for ever after the second or third file.
    Everything works perfectly fine on a single processor though.
    Now, to make things clearer: When i use ROMIO (MPI IO) it got stuck during opining the file (MPI_FILE_OPEN).
    However, i tried regular open(....) at the root processor and then reducing the data to the root processor and write there. The code got stuck at the MPI_REDUCE call.
    If i eliminated all the processors communication and just do dump IO (both ways), it runs fine but it slows down significantly when dumping the data.
    I tried on three different clusters(all linux) and i got the same problem.
    I don't want say what i think is the problem, i don't really know, but if the experts here can help i will appreciate.
     Thanks
    On Sun, Mar 14, 2010 at 12:50 PM, hossam <hossam.elasrag at gmail.com> wrote:
      This is my first post to the mpi-forum. I have a runtime problem related to MPI using MPICH2. I wonder if this is the correct forum to post my problem.
      Please let me know so i can proceed forward with my problem details.
      Thanks
  mpich-discuss mailing list
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100315/16e2acff/attachment.htm>
