[mpich-discuss] MPI I/O SLOW- possible conflicting with	communication....code stuck for ever during IO
    hossam
    hossam.elasrag at gmail.com
    Sun Mar 14 13:56:53 CDT 2010
I think i have a well defined problem i wonder if someone can give an
advice.
I am running an MPI code (MPICH2) on a linux cluster.
When i run the code with no IO inside the main runtime loop. It works
perfectly fine on any number of processors and nodes. When i start dumping
data during the loop
the code get stuck for ever after the second or third file.
Everything works perfectly fine on a single processor though.
Now, to make things clearer: When i use ROMIO (MPI IO) it got stuck during
opining the file (MPI_FILE_OPEN).
However, i tried regular open(....) at the root processor and then reducing
the data to the root processor and write there. The code got stuck at the
MPI_REDUCE call.
If i eliminated all the processors communication and just do dump IO (both
ways), it runs fine but it slows down significantly when dumping the data.
I tried on three different clusters(all linux) and i got the same problem.
I don't want say what i think is the problem, i don't really know, but if
the experts here can help i will appreciate.
 Thanks
On Sun, Mar 14, 2010 at 12:50 PM, hossam <hossam.elasrag at gmail.com> wrote:
> Hi,
> This is my first post to the mpi-forum. I have a runtime problem related to
> MPI using MPICH2. I wonder if this is the correct forum to post my problem.
> Please let me know so i can proceed forward with my problem details.
> Thanks
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100314/cab45da8/attachment.htm>
