[mpich-discuss] mpich2-1.2.1p1 - No rule to make target `all'
    Preeti
    preeti at csa.iisc.ernet.in
    Thu Mar 11 05:07:14 CST 2010
Hello
I have rebuilt everything from scratch and did vpath build.
I set the following
export F90=gfortran
export F77=gfortran
export LD_LIBRARY_PATH=/usr/lib64:/lib:/usr/lib
export LD_RUN_PATH=/usr/lib64:/lib:/usr/lib
/home/vss/preeti/bin/mpich2-1.2.1p1/configure
--prefix=/home/vss/preeti/bin/2-1.2.1p1 --enable-f90 2>&1 | tee c.log
make 2>&1 | tee m.log
Then I get the error
Making all in mpl
/bin/sh: line 17: cd: mpl: No such file or directory
make[3]: *** [all-recursive] Error 1
The files are attached.
Please help.
Thanks
Preeti
On Thu, Mar 11, 2010 at 1:53 AM, <chan at mcs.anl.gov> wrote:
> I don't think setting F77 and F90 causes the problem that
> you are seeing.  The directories or subpackges that have
> problems use a different build system than the majority of
> mpich2 base, so it could be that there is bugs in the build system
> in those subpackage.
> Since you didn't do "make distclean" before you reconfigure, so
> the m.log(.old) do not tell me much. Can you rebuild everything
> from scratch ?  i.e. untar the mpich2 tarball in a different location.
> Instead of doing an inpath build (i.e. cd mpich2-1.2.1p1/ ;
> ./configure....),
> could you do a VPATH build as documented in the README (search for the
> word VPATH)?  Send us the configure and make outputs again
> (be sure to add 2>&1 in creating the output files).
> A.Chan
> ----- "Preeti" <preeti at csa.iisc.ernet.in> wrote:
> > Hello
> > Thank you for the quick response.
> > I forgot to mention that I had set two flags earlier.
> > export F90=gfortran
> > export F77=gfortran
> > The earlier problem is gone when I compiled without setting these. I
> > am
> > attaching all log files, the earlier ones and the new ones.
> > Now I am facing another error which is from "make install 2>& | tee
> > mi.log"
> > /usr/bin/install: cannot create regular file `/index.htm': Permission
> > denied
> > Probably some variable is not set. I tried setting docdir too.
> > mi.log is also attached.
> > Please help.
> > Thanks
> > Preeti
> > On Wed, Mar 10, 2010 at 9:33 PM, <chan at mcs.anl.gov> wrote:
> > > It is unclear what went wrong based on what you've provided so far.
> > > Can you send us the configure and make outputs as stated in the
> > > README (be sure to include the stderr in the output file) ?
> > > > Hello
> > > > I am trying to install mpich2-1.2.1p1 on a 64-bit Linux system.
> > > > Configuration was successful.
> > > > ./configure --prefix=$HOME/local/mpich2-1.2.1 --enable-f90 | tee
> > > > c.log
> > > BTW, you didn't include stderr in c.log.  Depends on the shell you
> > > use, you need to either add "&" or "2>&1".  See README for
> > details..
> > > A.Chan
> > > _______________________________________________
> > > mpich-discuss mailing list
> > > mpich-discuss at mcs.anl.gov
> > > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> > > This message has been scanned for viruses and
> > > dangerous content by MailScanner, and is
> > > believed to be clean.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100311/ea5ec4c9/attachment-0001.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100311/ea5ec4c9/attachment-0003.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100311/ea5ec4c9/attachment-0004.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100311/ea5ec4c9/attachment-0005.obj>
