[mpich-discuss] mpich2-1.2.1p1 - No rule to make target `all'
    Preeti
    preeti at csa.iisc.ernet.in
    Wed Mar 10 13:38:53 CST 2010
Hello
Thank you for the quick response.
I forgot to mention that I had set two flags earlier.
export F90=gfortran
export F77=gfortran
The earlier problem is gone when I compiled without setting these. I am
attaching all log files, the earlier ones and the new ones.
Now I am facing another error which is from "make install 2>& | tee mi.log"
/usr/bin/install: cannot create regular file `/index.htm': Permission denied
Probably some variable is not set. I tried setting docdir too.
mi.log is also attached.
Please help.
Thanks
Preeti
On Wed, Mar 10, 2010 at 9:33 PM, <chan at mcs.anl.gov> wrote:
> It is unclear what went wrong based on what you've provided so far.
> Can you send us the configure and make outputs as stated in the
> README (be sure to include the stderr in the output file) ?
> ----- "Preeti" <preeti at csa.iisc.ernet.in> wrote:
> > Hello
> > I am trying to install mpich2-1.2.1p1 on a 64-bit Linux system.
> > Configuration was successful.
> > ./configure --prefix=$HOME/local/mpich2-1.2.1 --enable-f90 | tee
> > c.log
> BTW, you didn't include stderr in c.log.  Depends on the shell you
> use, you need to either add "&" or "2>&1".  See README for details..
> A.Chan
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
> This message has been scanned for viruses and
> dangerous content by MailScanner, and is
> believed to be clean.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100311/f1776784/attachment-0001.htm>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100311/f1776784/attachment-0004.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100311/f1776784/attachment-0005.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100311/f1776784/attachment-0006.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100311/f1776784/attachment-0007.bin>
Type: application/x-trash
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100311/f1776784/attachment-0003.old>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100311/f1776784/attachment-0004.old>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100311/f1776784/attachment-0005.old>
