[mpich-discuss] ROMIO: view and type_indexed with holes at the end
    Pascal Deveze
    Pascal.Deveze at bull.net
    Tue Mar  9 04:09:21 CST 2010
Hi Rob,
You have right, it is a misunderstanding, the problem is solved. Thanks
for your quick help.
Pascal
Rob Ross a écrit :
> Hi Pascal,
> I believe that the issue is simply one of a misunderstanding of the
> MPI datatype system.
> Zero length elements of an indexed type do not contribute to the
> typemap, so they can be ignored. You can add as many zero-length
> elements as you liked, at any position you wanted, and they will not
> change the effective type. If you want to introduce holes as you say,
> you should use MPI_Type_create_resized() instead.
> This mainly boils down to getting the extent of your type correct. You
> are trying to get the extent of your type to be equal to disp[2] *
> sizeof(integer) in your code, but my expectation is that if you used
> MPI_Type_get_extent() on the type that you have created, you would see
> sizeof(integer) instead -- there's only one integer of data. The
> reason that you want the extent to be bigger is that when ROMIO tiles
> the type, the next type is positioned at the end of the extent of the
> previous one (more or less); that's what creates the hole at the end
> of the type, not a zero-length element.
> Likewise the first zero-length element in your type doesn't really do
> anything. Instead you want the LB of your type to be zero. This is
> also handled with MPI_Type_create_resized().
> So try this instead.
> lng[0] = 1;
> dsp[0] = 1;
> MPI_Type_create_indexed(1, lng, dsp, MPI_INTEGER, &offtype);
> MPI_Type_create_resized(offtype, 0, hole_position * sizeof(integer),
> &filetype);
> MPI_Type_commit(&filetype);
> Rob
> On Mar 8, 2010, at 7:23 AM, Pascal Deveze wrote:
>> Sorry, I forget the programm file
>> Here it is.
>> Pascal
>> Pascal Deveze a écrit :
>>> Hi all,
>>> I found a strange behaviour of  ROMIO with a type indexed datatype
>>> that is contains holes.
>>> My definition:
>>>      lng[0]= 0;
>>>      dsp[0]= 0; ==> hole at first element
>>>      lng[1]= 1;
>>>      dsp[1]= 1; ===> one element
>>>      lng[2]= 0;
>>>      dsp[2]= 3; ====> hole at the end
>>>      MPI_Type_indexed(3, lng, dsp, MPI_INTEGER, &filetype);
>>>      MPI_File_open(MPI_COMM_SELF, filename, MPI_MODE_RDONLY ,
>>> MPI_INFO_NULL, &fh);
>>>      MPI_File_set_view(fh, 0, MPI_INTEGER, filetype,"native",
>>> MPI_INFO_NULL);
>>> This definition works fine: One element with one hole at the
>>> beginning and 2 holes at the end.
>>> It works also fine when dsp[2] > 3.
>>> But it does not work with dsp[2]=2. In that case, there is no hole
>>> at the end.
>>> Attached is a small program to reproduce the error.
>>> I do not find if the MPI standard allows to introduce "holes" in the
>>> indexed datatype (specifiing lng[i]=0) or does'nt.
>>> In any case, it seems to work in all cases excepted if only one hole
>>> is specified at the end (dsp[2] = 2).
>>> Is this a bug in ROMIO or a limit of the MPI standard ?
>>> Pascal
>>> _______________________________________________
>>> mpich-discuss mailing list
>>> mpich-discuss at mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>> #include <stdio.h>
>> #include "mpi.h"
>> #define SIZE 1000
>> char filename[256]="/mnt/fs3/devezep/VIEW_TEST";
>> int i, j, myid, dsp[3], lng[3], buffer[SIZE];
>> MPI_Status status;
>> MPI_File fh;
>> MPI_Datatype filetype;
>> int main(int argc, char **argv) {
>> MPI_Init(&argc, &argv);
>> MPI_Errhandler_set(MPI_COMM_WORLD, MPI_ERRORS_ARE_FATAL);
>> MPI_Comm_rank(MPI_COMM_WORLD, &myid);
>> if (!myid) {
>>    MPI_File_open(MPI_COMM_SELF, filename, MPI_MODE_CREATE |
>> MPI_MODE_RDWR , MPI_INFO_NULL, &fh);
>>    MPI_File_set_errhandler(fh, MPI_ERRORS_ARE_FATAL);
>>    for (i=0; i<SIZE; i++) buffer[i] = i;
>>    MPI_File_write(fh, buffer, SIZE, MPI_INTEGER, &status);
>>    MPI_File_close(&fh);
>> // loop for test :
>>    for (i=2 ; i<4 ; i++) {
>>       lng[0]= 0;
>>       dsp[0]= 0;
>>       lng[1]= 1;
>>       dsp[1]= 1;
>>       lng[2]= 0;
>>       dsp[2]= i;
>> MPI_INFO_NULL);
>>       MPI_File_read(fh, buffer, 5, MPI_INTEGER, &status);
>>       printf("data read with view for i=%d => lng[0]=%d dsp[0]=%d
>> lng[1]=%d dsp[1]=%d lng[2]=%d dsp[2]=%d :",
>>             i, lng[0], dsp[0], lng[1], dsp[1], lng[2], dsp[2]);
>>       for (j=0 ; j<5 ; j++) printf("%x ", buffer[j]);
>>       if (buffer[1] != (i+2)) printf("\n =======>  test KO for i=%d :
>> buffer[1]=%d instead of %d \n", i, buffer[1], i+2);
>>       else printf("\n =======> test OK for i=%d\n", i);
>>       MPI_Type_free(&filetype);
>> MPI_Barrier(MPI_COMM_WORLD);
>> MPI_Finalize();
