[mpich-discuss] Latency or the B/W, which is the bottleneck for most MPI codes?
Micha Feigin
michf at post.tau.ac.il
Sun Mar 7 09:45:26 CST 2010
Depends,
Short messages will be more affected by latency, long messages will be more affected by B/W.
On Fri, 5 Mar 2010 14:55:32 -0600
junli gu <junligu at illinois.edu> wrote:
> Hi everyone:
> I am wondering to most MPI codes, which is the performance bottleneck, the
> latency or the B/W?
> I am doing research to optimize the cache-coherent shared memory
> architecture to run MPI codes more efficiently. Although I am trying to
> reduce the latency for message data transferring, then I realized that maybe
> the B/W is the real bottleneck. I have heard the comments that most
> well-written MPI codes are not latency-sensitive but B/W sensitive. So
> instead of making single message transfer faster, increasing the B/W to
> transfer the chunk of data faster is the right way to improve performance.
> Can you give us some comments about this?
> Thank you in advance!
