[mpich-discuss] MPICH associating process with a core
    chong tan
    chong_guan_tan at yahoo.com
    Tue Mar  2 12:26:58 CST 2010
John,
what kind of simulator are you working on ?
tan
Sent: Tue, March 2, 2010 9:41:23 AM
Subject: Re: [mpich-discuss] MPICH associating process with a core
Thanks, Tan.
Could you elaborate a little more about where the process dumps the
information to?
Unfortunately my simulator does not have good user interface where I
can have secondary
windows to report TOP on it.
Maybe there are some syscal available to print the info out in the
program itself.
john
On Tue, Mar 2, 2010 at 11:17 AM, chong tan <chong_guan_tan at yahoo.com> wrote:
> I was looking for this a while back, and found none.  I created a work
> around for
> myself:
> each process dumps its rank and process id at the begining of the run (into
> somewhere),
> and I map those id to the output of 'top' (that show the CPU binding).  you
> can google info on
> enabling CPU info with top.
> tan
> ________________________________
> From: John Xu <johnzxu at gmail.com>
> Sent: Mon, March 1, 2010 11:04:59 PM
> Subject: [mpich-discuss] MPICH associating process with a core
> Hi,
> Is there a way in the MPI library to report which process is running
> on which core in a SMP system with
> shared memory MPI programming model?
> I dug out the library calls and only found out
> MPI_Get_processor_name to be close. But it reports the machine itself
> not the core the process is running
> on.
> thanks,
> john
> mpich-discuss mailing list
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100302/2a5e8660/attachment.htm>
