[mpich-discuss] A problem of carrying out mpich2
    Dave Goodell
    goodell at mcs.anl.gov
    Tue Jun 15 13:21:32 CDT 2010
Signal 9 is SIGKILL, and in the context of MPI (or at least MPICH2+mpd) usually means that the process manager killed the application because of some other problem.  The other problem is often another process crashing, such as from a signal 11 (SIGSEGV).  Unfortunately, the other failing process does not always show up in the output.  If you enable core dumps (usually "ulimit -c unlimited") then sometimes you'll get a core dump for the offending process.
Our new process manager, hydra, does a better job with the error reporting and process cleanup.  However you need to use a fairly modern version of MPICH2 in order to use hydra: http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager
-Dave
On Jun 15, 2010, at 10:45 AM PDT, Yuriy Khalak wrote:
> Dear Qianlin,
> Signal 9, which seems to be causing the crash, usually indicates a segmentation fault in the code bing run by mpiexec. I had something similar happen to me recently under c++ and mpich. Turned out I was trying to delete the contents of a pointer twice.
> In my case Linux did a core dump, which I could trace with gdb and determine approximately where the segmentation fault occurred. So if you can find a core dump in your program's working directory, the problem is probably in the VASP code, not in mpich2.
> Keep in mind that I'm just a user of mpich2 and very well could be wrong.
> Regards,
>              Yuriy
> > Dear mpich2-support,
> > Based on mpif90, I have installed the parallel version of a commercilal code VASP . Sometimes mpich2 can work well with vasp, but it also failed for some VASP-treated jobs with the following error messages:
> > running on    8 nodes
> > distr:  one band on    1 nodes,    8 groups
> > vasp.4.6.21  23Feb03 complex
> > POSCAR found :  3 types and   30 ions
> > LDA part: xc-table for Ceperly-Alder, Vosko type interpolation para-ferro
> > POSCAR, INCAR and KPOINTS ok, starting setup
> > WARNING: wrap around errors must be expected
> > mpiexec_qltang1 (handle_stdin_input 1089): stdin problem; if pgm is run in background, redirect from /dev/null
> > mpiexec_qltang1 (handle_stdin_input 1090):     e.g.: mpiexec -n 4 a.out < /dev/null &
> > FFT: planning ...            2
> > reading WAVECAR
> > WARNING: random wavefunctions but no delay for mixing, default for NELMDL
> > entering main loop
> >       N       E                     dE             d eps       ncg     rms          rms(c)
> > rank 6 in job 36  qltang1_54199   caused collective abort of all ranks
> >  exit status of rank 6: killed by signal 9
> > rank 3 in job 36  qltang1_54199   caused collective abort of all ranks
> >  exit status of rank 3: killed by signal 9
> > I want to know how to solve the above question. Thank you alot.
> > Best regards,
> > Qianlin
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
