[mpich-discuss] A problem of carrying out mpich2
Dr. Qian-Lin Tang
qltang at xidian.edu.cn
Tue Jun 15 08:25:36 CDT 2010
Dear mpich2-support,
Based on mpif90, I have installed the parallel version of a commercilal code VASP . Sometimes mpich2 can work well with vasp, but it also failed for some VASP-treated jobs with the following error messages:
running on 8 nodes
distr: one band on 1 nodes, 8 groups
vasp.4.6.21 23Feb03 complex
POSCAR found : 3 types and 30 ions
LDA part: xc-table for Ceperly-Alder, Vosko type interpolation para-ferro
POSCAR, INCAR and KPOINTS ok, starting setup
WARNING: wrap around errors must be expected
mpiexec_qltang1 (handle_stdin_input 1089): stdin problem; if pgm is run in background, redirect from /dev/null
mpiexec_qltang1 (handle_stdin_input 1090): e.g.: mpiexec -n 4 a.out < /dev/null &
FFT: planning ... 2
reading WAVECAR
WARNING: random wavefunctions but no delay for mixing, default for NELMDL
entering main loop
N E dE d eps ncg rms rms(c)
rank 6 in job 36 qltang1_54199 caused collective abort of all ranks
exit status of rank 6: killed by signal 9
rank 3 in job 36 qltang1_54199 caused collective abort of all ranks
exit status of rank 3: killed by signal 9
I want to know how to solve the above question. Thank you alot.
Best regards,
Qianlin
