[mpich-discuss] Help me for installing mpich2 on Red Hat 9
    mahaiyuan
    haiyuanma at live.cn
    Tue Jun  1 06:08:49 CDT 2010
Hello everybody!
I installled MPICH2 failed. Need you help.
My processor is intel e5300, 2600 MHz (13 x 200). Operating system is Red Hat Linux 9.
I installed MPI following the "mpich2-1.2.1-installguide.pdf".
In step 8, I added the bin subdirectory of the installation directory to my path:
export PATH=/home/mhy/mpich2-install/bin:$PATH
then checked it:
[root at localhost mpich2-1.2.1p1]# which mpd
/home/mhy/mpich2-install/bin/mpd
[root at localhost mpich2-1.2.1p1]# which mpicc
/home/mhy/mpich2-install/bin/mpicc
[root at localhost mpich2-1.2.1p1]# which mpiexec
/home/mhy/mpich2-install/bin/mpiexec
[root at localhost mpich2-1.2.1p1]# which mpirun
/home/mhy/mpich2-install/bin/mpirun
All aboves are OK.
The next step was editing the file mpd.conf. I logged in Linux as root. So I created a file named mpd.conf in the directory /etc and
cd /home
touch mpd.conf
chmod 600 mpd.conf
Then I edited mpd.conf with the line secretword="my secretword"
When I checked the sanity, the errors turned out:
[root at localhost mpich2-1.2.1p1]# mpd &
Traceback (most recent call last):
  File "/home/mhy/mpich2-install/bin/mpd", line 87, in ?
    from sets import Set as set
ImportError: No module named sets
[root at localhost mpich2-1.2.1p1]# mpdtrace
mpdroot: perror msg: No such file or directory
mpdroot: cannot connect to local mpd at: /tmp/mpd2.console_root
    probable cause:  no mpd daemon on this machine
    possible cause:  unix socket /tmp/mpd2.console_root has been removed
mpdtrace (__init__ 1208): forked process failed; status=255
[root at localhost mpich2-1.2.1p1]# mpdallexit
mpdallexit (__init__ 1208): forked process failed; status=255
Can somegody help me out? Thanks very much!
yours sincerely
Haiyuan Ma
_________________________________________________________________
SkyDrive电子画册,带你领略精彩照片,分享“美”时“美”刻!
http://www.windowslive.cn/campaigns/e-magazine/ngmchina/?a=c
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100601/929749f4/attachment.htm>
