[mpich-discuss] ROMIO: ADIOI_Calc_my_off_len (patch proposed for adio/comm/ad_read_coll.c)
Rob Ross
rross at mcs.anl.gov
Tue Jul 27 09:20:18 CDT 2010
Hi Pascal,
The code is purposefully skipping blocks of length zero because there
is no data in them. Until we hit a block with data in it, we have not
found an offset.
Perhaps I don't understand. Can you provide an example code that would
exhibit a problem with the code as it exists now?
Rob
On Jul 27, 2010, at 7:47 AM, Pascal Deveze wrote:
> At line 379 of adio/common/ad_read_coll.c, if flat_file-
> >blocklens[i] is null, the code continue.
> But in the case where i is null (first loop), the first calculated
> offset is false.
> 369 if (file_ptr_type == ADIO_INDIVIDUAL) {
> 370 /* Wei-keng reworked type processing to be a bit
> more efficient */
> 371 offset = fd->fp_ind - disp;
> 372 n_filetypes = (offset - flat_file->indices[0]) /
> filetype_extent;
> 373 offset -= (ADIO_Offset)n_filetypes *
> filetype_extent;
> 374 /* now offset is local to this extent */
> 375
> 376 /* find the block where offset is located, skip
> blocklens[i]==0 */
> 377 for (i=0; i<flat_file->count; i++) {
> 378 ADIO_Offset dist;
> 379 if (flat_file->blocklens[i] == 0) continue;
> 380 dist = flat_file->indices[i] + flat_file-
> >blocklens[i] - offset;
> 381 /* frd_size is from offset to the end of block
> i */
> 382 if (dist == 0) {
> 383 i++;
> 384 offset = flat_file->indices[i];
> 385 frd_size = flat_file->blocklens[i];
> 386 break;
> 387 }
> 388 if (dist > 0) {
> 389 frd_size = dist;
> 390 break;
> 391 }
> 392 }
> 393 st_index = i; /* starting index in flat_file-
> >indices[] */
> 394 offset += disp +
> (ADIO_Offset)n_filetypes*filetype_extent;
> 395 }
> I propose not to skip blocklens[i]==0
> diff -u ad_read_coll.c.old ad_read_coll.c
> --- ad_read_coll.c.old 2008-11-13 17:54:08.000000000 +0100
> +++ ad_read_coll.c 2010-07-27 14:45:11.000000000 +0200
> @@ -373,10 +373,9 @@
> offset -= (ADIO_Offset)n_filetypes * filetype_extent;
> - /* find the block where offset is located, skip
> blocklens[i]==0 */
> + /* find the block where offset is located */
> ADIO_Offset dist;
> - if (flat_file->blocklens[i] == 0) continue;
> /* frd_size is from offset to the end of block i */
> if (dist == 0) {
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
