[mpich-discuss] Number processes/CPU in Hydra -hostlist
Yauheni Zelenko
zelenko at cadence.com
Mon Jul 26 13:56:15 CDT 2010
Hi!
I want to suggest next patch which will allow to specify number of processes/CPU in -hostlist command line option in Hydra.
Goal is to provide similar functionality as Platform LSF's LSB_MCPU_HOSTS.
Host name and number of CPUs may be separated with colon or space.
Changes are in /home/zelenko/Installs/GCC4.4.0/mpich2-1.3a2.src/src/pm/hydra/ui/mpich/utils., hostlist_fn()
while (hostname) {
status = HYDU_add_to_node_list(hostname, 1, &HYD_handle.node_list);
HYDU_ERR_POP(status, "unable to add to node list\n");
hostname = strtok(NULL, ",");
to:
while (hostname) {
char* num_procs_str = NULL;
int num_procs = 1;
num_procs_str = strchr(hostname, ':');
if (!num_procs_str)
num_procs_str = strchr(hostname, ' ');
if (num_procs_str)
*num_procs_str = '\0';
num_procs_str++;
num_procs = atoi(num_procs_str);
status = HYDU_add_to_node_list(hostname, num_procs, &HYD_handle.node_list);
Eugene.
