[mpich-discuss] MPICH2 and TORQUE/PBS integration
Ivan Pulido
mefistofeles87 at gmail.com
Mon Jul 26 10:44:43 CDT 2010
On Fri, Jul 23, 2010 at 6:24 PM, Pavan Balaji <balaji at mcs.anl.gov> wrote:
> Ivan,
> Can you try using the Hydra process manager?
> % mpiexec.hydra -rmk pbs ./application
This didn't work, I'm not sure if this has to be with the way I've set up my
cluster. When I try running that command specifying 20 nodes (-n 20) all the
jobs are run on a single machine and the PBS server doesn't find out about
this application running (qstat doesn't shopw anything). Any ideas about
this subject are very welcome.
Thanks.
> -- Pavan
> On 07/23/2010 05:15 PM, Ivan Pulido wrote:
>> Hello, I'm trying to configure torque resource manager and MPICH2 (with
>> MPD) but Im having some issues.
>> The MPICH2 user's guide says there's a way to convert the Torque node file
>> to one MPD can read, but this is outdated since the syntax used by torque
>> nowadays is not the one mentioned on MPICH2 user's guide, so I can't use
>> what's there to use Torque with MPICH2. On the other hand, I tried using OSC
>> mpiexec http://www.osc.edu/~djohnson/mpiexec/<http://www.osc.edu/%7Edjohnson/mpiexec/>with no good results since it's looking for a libpbs.a that's not part of
>> Torque default install (this is for torque's mailling list).
>> So, what I'm trying to tell is that the ways the user's guide advice to
>> use MPICH2 with torque functionality are not correct with newest versions of
>> the software involved. So I'd like to know if there's a way to use MPICH2
>> with torque functionality that really works with newest versions, I'd really
>> like a help with this since we need using MPI in our cluster urgently.
>> Thanks.
>> Ivan Pulido
>> Estudiante de Física
>> Universidad Nacional de Colombia
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji <http://www.mcs.anl.gov/%7Ebalaji>
Ivan Pulido
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100726/7706137c/attachment.htm>
