[mpich-discuss] intercommunicator support in MPICH
Dave Goodell
goodell at mcs.anl.gov
Tue Jul 20 11:32:16 CDT 2010
Intercommunicators are definitely supported in MPICH2. You probably have MPICH installed instead, which does not support intercommunicators (nor is it supported in general). Point-to-point performance in intercommunicators should generally be identical to performance in intracommunicators. Collective communication routines for intercommunicators have not been extensively tuned, so they may not quite perform as well as they could, depending on the particular collective and way it is invoked.
-Dave
On Jul 20, 2010, at 8:05 AM CDT, Rob Latham wrote:
> Hi Jim. I'm interested in hearing more about how this async i/o
> strategy plays out on other platforms.
> I'm moving this to the mpich-discuss list, because as far as I know
> intercommunicators are supported on MPICH2, but the folks on the
> mpich-discuss list will be able to speak with more authority on that
> matter.
> What is it about intercommunicators that does not work for you? Are
> you splitting up COMM_WORLD to form comp_comm and io_comm ?
> There might be performance implications with intercommunicators. Can
> the link between the two sets be the bottleneck here? I presume you
> are transferring a lot of data to io_comm.
> MPICH guys, Jim's original email is below.
> ==rob
> On Mon, Jul 19, 2010 at 04:44:50PM -0600, Jim Edwards wrote:
>> Hi All,
>> I have created a new repository branch and checked in the beginnings of a
>> version of pio which allows the io tasks to be a disjoint set of tasks from
>> those used for computation.
>> The io_comm and the comp_comm are disjoint and pio_init
>> is called with an intercommunicator which spans the two task sets. The
>> compute task set returns while the io task set waits in a call back loop for
>> further instructions.
>> I have added three new tests in the pio test suite and all of them pass on
>> bluefire. Then I discovered that the mpich does not support mpi
>> intercommunicators. These are part of the mpi-2 standard and I thought
>> that all of the mpi implementations were there by now? Apparently not. Is
>> there another mpi implementation that we can try on jaguar or edinburgh?
>> Currently all of the pio commands are still syncronous calls - that is the
>> compute tasks cannot continue until the write has completed, my eventual
>> plan is to relax this requirement to see if there is a performance advantage
>> - but if AIX-POE is the only environment to support this model I may have to
>> rethink the approach.
>> If you get a chance please have a look at the implementation in
>> https://parallelio.googlecode.com/svn/branches/async_pio1_1_1/
>> If enough of you are interested we can schedule a con-call to go over how it
>> works and some of the things that still need to be done.
>> Jim
> Rob Latham
> Mathematics and Computer Science Division
> Argonne National Lab, IL USA
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
