[mpich-discuss] mpich2 installation problem
Pavan Balaji balaji at mcs.anl.gov
Mon Jul 19 22:28:21 CDT 2010
Ann,
Thanks for the detailed report.
MPD is not tested with different user names on different hosts. So, I'm
not sure if it'll work correctly in that case.
Can you try mpiexec.hydra instead? That's not tested for that case
either, but I think it might work. Hydra usage instructions are
available here:
http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager
  -- Pavan
On 07/19/2010 07:48 PM, Ann Irvine wrote:
> I believe I have successfully built and installed MPICH2 (mpd, mpicc,
> mpiexec, and mpirun all are appropriately referenced). I have also
> successfully done the local machine sanity checks described in the
> installation document and have successfully passed a message between a
> server and client on a single (local) machine.
> However, I haven't been able to complete the tests. I believe I have
> narrowed the problem to the debugging section on page 37 of the
> install.pdf guide. My mpdcheck checks are failing (shown below in 1
> and 2).
> I further think there is a problem with the MPI installation because
> upon installing mpi4py, I am having problems importing MPI in a python
> script. There, I receive the error in 3 (below).
> I hope this is descriptive enough to receive some help. Please let me
> know if it's not!
> Thank you,
> Ann
> ***************1****************
> ann-irvines-macbook-pro:mpich2-1.2.1p1 anni$ mpdcheck -f mpd.hosts
> *** gethostbyaddr failed for this hosts's IP 128.9.184.140
> *** gethostbyname_ex failed for host anni at login.clsp.jhu.edu
> *** gethostbyname_ex failed for host akirvine at hpc.usc.edu
> *** gethostbyname_ex failed for host anni at nitro.usc.edu
> ***************2****************
> ann-irvines-macbook-pro:mpich2-1.2.1p1 anni$ mpdcheck -pc
> --- print results of: gethostbyname_ex(gethostname())
> ('ann-irvines-macbook-pro.local', [], ['128.9.184.140'])
> --- try to run /bin/hostname
> --- try to run uname -a
> sh: /bin/uname: No such file or directory
> --- try to print /etc/hosts
> # Host Database
> # localhost is used to configure the loopback interface
> # when the system is booting.  Do not change this entry.
> 127.0.0.1	localhost
> 255.255.255.255	broadcasthost
> ::1             localhost
> fe80::1%lo0	localhost
> --- try to print /etc/resolv.conf
> # Mac OS X Notice
> # This file is not used by the host name and address resolution
> # or the DNS query routing mechanisms used by most processes on
> # this Mac OS X system.
> # This file is automatically generated.
> domain isi.edu
> nameserver 128.9.144.145
> nameserver 128.9.64.64
> --- try to run /sbin/ifconfig -a
> lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
> 	inet6 ::1 prefixlen 128
> 	inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
> 	inet 127.0.0.1 netmask 0xff000000
> gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280
> stf0: flags=0<> mtu 1280
> en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
> 	ether 00:26:b0:e6:17:dc
> 	media: autoselect status: inactive
> 	supported media: none autoselect 10baseT/UTP <half-duplex>
> 10baseT/UTP <full-duplex> 10baseT/UTP <full-duplex,flow-control>
> 10baseT/UTP <full-duplex,hw-loopback> 100baseTX <half-duplex>
> 100baseTX <full-duplex> 100baseTX <full-duplex,flow-control> 100baseTX
> <full-duplex,hw-loopback> 1000baseT <full-duplex> 1000baseT
> <full-duplex,flow-control> 1000baseT <full-duplex,hw-loopback>
> en1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
> 	inet6 fe80::226:bbff:fe0c:5fd9%en1 prefixlen 64 scopeid 0x5
> 	inet 128.9.184.140 netmask 0xfffff000 broadcast 128.9.191.255
> 	ether 00:26:bb:0c:5f:d9
> 	media: autoselect status: active
> 	supported media: autoselect
> fw0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 4078
> 	lladdr 00:26:b0:ff:fe:e6:17:dc
> 	media: autoselect <full-duplex> status: inactive
> 	supported media: autoselect <full-duplex>
> --- try to print /etc/nsswitch.conf
> cat: /etc/nsswitch.conf: No such file or directory
> ***************3****************
>   File "demo/helloworld.py", line 6, in <module>
>     from mpi4py import MPI
> ImportError: dlopen(/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages/mpi4py-1.2.1-py2.7-macosx-10.5-fat3.egg/mpi4py/MPI.so,
> 2): Symbol not found: _MPI_Dist_graph_create
>   Referenced from:
>   Expected in: flat namespace
>  in /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages/mpi4py-1.2.1-py2.7-macosx-10.5-fat3.egg/mpi4py/MPI.so
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
Pavan Balaji
http://www.mcs.anl.gov/~balaji
