[mpich-discuss] R: Re: mpich2 and windows 7
mgianeselli at libero.it mgianeselli at libero.it
Wed Jul 14 12:14:04 CDT 2010
Hi
Thank you very much,now it works also in windows 7 64 bit; the only way I
found is to install first of all mpich2 1.2.1 64 bit and then the 32 bit
version.
I have just to remember to close the firewall when I use mpiexec.
Regards
Michele
>----Messaggio originale----
>Da: jayesh at mcs.anl.gov
>Data: 14/07/2010 2.58
>A: <mgianeselli at libero.it>, <mpich-discuss at mcs.anl.gov>
>Ogg: Re: [mpich-discuss] mpich2 and windows 7
>Hi,
> Did you get any error messages during the installation process ? You have to
launch the installer from an admin command prompt for the installation to
succeed (Right-click on command prompt icon - select "Run as administrator" -
Use msiexec utility, "msiexec /i mpich2-1.2.1p1-win-x86-64.msi", to install
MPICH2 from the command prompt.).
> And as Dave suggested we currently don't provide the wrapper utils with 64-
bit version (These should be available in the upcoming version though) and
hence no associated startup menu items.
> Let us know if it helps.
>Regards,
>Jayesh
>----- Original Message -----
>From: mgianeselli at libero.it
>To: mpich-discuss at mcs.anl.gov
>Sent: Friday, July 9, 2010 8:29:31 AM GMT -06:00 US/Canada Central
>Subject: [mpich-discuss] mpich2 and windows 7
>Good morning
>I used mpich2 32 bit on windows xp and everything works well.
>Now I am installing mpich2 64 bit on windows 7 but I have some problem; the
>installtion complete successfully but I am not able to find mpich2 folder on
>start menu and if I try the double click on the installation folder on the
file
>mpiexec nothing happened.
>Could you help me?
>Thank you in advance
>Michele
>_______________________________________________
>mpich-discuss mailing list
>https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
