[mpich-discuss] Credentials Rejected - Windows Vista/7 Home Premium
Jayesh Krishna
jayesh at mcs.anl.gov
Tue Jul 13 19:42:54 CDT 2010
If you are installing MPICH2 on a 64-bit machine we recommend that you install the 64-bit version of MPICH2 (http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads). Try if it works.
From the error message, It looks like the username/password combination is not valid.
Is "Schwer" a domain user (on domain SECS8)? Try accepting the default username (Press Enter key when prompted for the username with the "-register" option) and provide the password when prompted and see if it works.
Let us know the results.
Jayesh
----- Original Message -----
Sent: Thursday, July 8, 2010 9:55:44 AM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] Credentials Rejected - Windows Vista/7 Home Premium
Hello --
I have a successful Windows XP 32 bit install of MPICH2.
I have attempted installs on two other boxes: Windows Vista and Windows 7,
both 64 bit. As far as I can tell the install went well.
My problem is getting either install to recognize my username/password.
Below is a command window session where the command window was launched
using "Run as Administrator"
C:\Windows\system32>mpiexec -remove
Account and password removed from the Registry.
C:\Windows\system32>mpiexec -register
account (domain\user) [SECS8\Schwer]:
password:
confirm password:
Password encrypted into the Registry.
C:\Windows\system32>mpiexec -n 1 hostname
Credentials for SECS8\Schwer rejected connecting to SECS8
Aborting: Unable to connect to SECS8
Any suggestions or pointers?
Thanks, --len
Len Schwer, PhD Schwer Engineering & Consulting Services
Len at Schwer.net 6122 Aaron Court
www.schwer.net Windsor CA 95492
707.837.0559 (Voice) 928.833.1130 (eFAX)
707.480.8056 (Mobile)
mpich-discuss mailing list
