[mpich-discuss] fail to run hello world program with MPICH2-1.3a2 on multiple nodes
Manhui Wang
wangm9 at cardiff.ac.uk
Fri Jul 9 06:26:10 CDT 2010
Hello,
I have a problem about running MPI jobs on multinodes with newly
released MPICH2-1.3a2, which hydra is the default process manager.
I just tested the simplest hello world program. It works fine on any
single node, but fails on multinodes.
node6-b:~/testprogram> cat hosts
node6-b
node6-b
node7-b
node7-b
node6-b:~/testprogram> mpiexec -f hosts -n 4 ./hello
node6-b: hello world,length=7,my rank=0
node6-b: hello world,length=7,my rank=1
node7-b: hello world,length=7,my rank=3
node7-b: hello world,length=7,my rank=2
Fatal error in PMPI_Barrier: Other MPI error, error stack:
PMPI_Barrier(476).................: MPI_Barrier(MPI_COMM_WORLD) failed
MPIR_Barrier(82)..................:
MPIC_Sendrecv(161)................:
MPIC_Wait(519)....................:
MPIDI_CH3I_Progress(165)..........:
MPID_nem_mpich2_blocking_recv(880):
MPID_nem_tcp_connpoll(1714).......: Communication error
MPID_nem_mpich2_blocking_recv(895):
APPLICATION TERMINATED WITH THE EXIT STRING: Terminated (signal 15)
I built the MPICH2-1.3a2 library with Intel 11.1/069 compilers on 64-bit
AMD machine:
nice -n +18 ./configure --with-device=ch3:nemesis
--prefix=/mympich2-install FC=ifort --enable-f90 F90=ifort --enable-f77
F77=ifort --enable-cc CC=icc --enable-cxx CXX=icc 2>&1 | tee configure.log
nice -n +18 make 2>&1 | tee make.log
nice -n +18 make install 2>&1 | tee install.log
Could you please point out what is the problem? I have attached the
source code.
Thanks
Manhui
Manhui Wang
School of Chemistry, Cardiff University,
Main Building, Park Place,
Cardiff CF10 3AT, UK
Telephone: +44 (0)29208 76637
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100709/176da6d4/attachment.cc>
