[mpich-discuss] command line ordering of hosts matters?
David_Lowinger at ea.epson.com David_Lowinger at ea.epson.com
Mon Jul 5 11:11:16 CDT 2010
Hi Jayesh,
Yes, I can run a simple non-MPI program (ie. the program "hostname")
successfully with "mpiexec -hosts 2 10.0.0.101 1 10.0.0.6 1 hostname".  I
see both hostnames get printed out, and then the program exits.  The
ordering of hosts does not matter in this case.
I see the exact same behavior as before when I provide the complete path
to the executable; ie. the MPI_Bcase never completes if I put 10.0.0.101
before 10.0.0.6.
I see the exact same behavior as before when I use the machinefile option.
With regards to checking the control panel, I assume you mean the
"Processes" tab of the Windows Task Manager?  If so, which processes
should I be looking for as the program runs?  I changed the MPI "hello
world" app to MPI_Bcast a very large buffer over and over, so that I can
look for some kind of process in the Windows Task Manager.  What is the
name of the process I should be looking for?  Thanks,
David
Jayesh Krishna <jayesh at mcs.anl.gov>
07/01/2010 11:54 AM
Expire Date: 07/04/2012
To
mpich-discuss at mcs.anl.gov
cc
Subject
Re: [mpich-discuss] command line ordering of hosts matters?
 Along with checking whether the processes are launched, please provide us
with the information below,
# Are you able to run a simple non-MPI program (mpiexec -hosts 2
10.0.0.101 1 10.0.0.6 1 hostname)?
# Try providing the complete path to the executable (mpiexec -hosts 2
10.0.0.101 1 10.0.0.6 1 c:\temp\helloworld.exe). Without the complete path
you might actually be executing two different MPI programs on the hosts.
# Does the machinefile option work (mpiexec -n 2 -machinefile mf.txt
c:\temp\helloworld.exe ; Where the file mf.txt contains the host
ipaddresses)?
Jayesh
----- Original Message -----
From: "David Lowinger" <David_Lowinger at ea.epson.com>
Sent: Wednesday, June 30, 2010 4:26:16 PM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] command line ordering of hosts matters?
Hi Jayesh,
On both machines, when I type, "smpd -version", both display "1.2.1p1".
When I call "MPI_Get_version()" on both machines, they both show version
2, subversion 2.
Both machines are running 64-bit Windows Vista.
I'll check the control panel to see if the MPI processes are being
launched.
David
06/30/2010 04:53 PM
Expire Date: 06/29/2012
To               mpich-discuss at mcs.anl.gov
cc               David_Lowinger at ea.epson.com
Subject                  Re: [mpich-discuss] command line ordering of
hosts matters?
Which version of MPICH2 are you using ?
Do the two machines have the same underlying architecture (MPICH2
currently does not support heterogeneous systems - So you cannot run your
job across 32-bit and 64-bit machines/MPICH2_libs)?
Also try checking the control panel to see if the MPI processes are being
launched on the machines.
Jayesh
Sent: Wednesday, June 30, 2010 3:42:22 PM GMT -06:00 US/Canada Central
Firewall is turned off on both machines.
There is no error message... the MPI_Bcase simply never completes. I've
left it running for 10 minutes, and the second printf ("completed
MPI_Bcast") never appears when I use the second host ordering below
("10.0.0.101 1 10.0.0.6 1").
When I run "smpd -status 10.0.0.6" from 10.0.0.101, I see the message
"smpd running on 10.0.0.6". When I run "smpd -status 10.0.0.101" from
10.0.0.6, I see the message "smpd running on 10.0.0.101".
06/30/2010 10:50 AM
Subject Re: [mpich-discuss] command line ordering of hosts matters?
Do you have a firewall running on any of these machines (If so, can you
try running your job after turning off the firewall)?
What is the error message that you get when you run your job ?
Can you try running "smpd -status REMOTE_MACHINE" from each of the
machines and let us know the results ("smpd -status 10.0.0.6" from
10.0.0.101 & "smpd -status 10.0.0.101" from 10.0.0.6)?
Jayesh
Sent: Tuesday, June 29, 2010 5:53:07 PM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] command line ordering of hosts matters?
When running a very basic "hello world" app, I've found that the app's
behavior depends on the order I use for hosts in the command line. For
example, if I use:
mpiexec -hosts 2 10.0.0.6 1 10.0.0.101 1 helloworld.exe
The program executes flawlessly. But, if I use:
mpiexec -hosts 2 10.0.0.101 1 10.0.0.6 1 helloworld.exe
then the program never gets past the call to "MPI_Bcast()". Here is my
code:
#include "mpi.h"
#define MPI_FLUSH() fflush(stdout)
int main( int argc, char* argv[] )
int g_Thread_ID, g_Num_Threads;
int test = 0;
* MPI Initialization *
MPI_Init(&argc, &argv);
MPI_Comm_rank(MPI_COMM_WORLD, &g_Thread_ID);
MPI_Comm_size(MPI_COMM_WORLD, &g_Num_Threads);
printf("thread %d: main: About to execute MPI_Bcast\n", g_Thread_ID);
MPI_FLUSH();
// Broadcast integer
int err = MPI_Bcast(&test, 1, MPI_INT, 0, MPI_COMM_WORLD);
printf("thread %d: completed MPI_Bcast\n", g_Thread_ID);
MPI_FLUSH();
MPI_Finalize();
I am running Windows Vista on both machines. Has anyone seen this before?
David
mpich-discuss mailing list
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100705/90c556af/attachment.htm>
