[mpich-discuss] [MSYS] fail to generate configure and makefile
Jayesh Krishna jayesh at mcs.anl.gov
Fri Jul 2 12:11:37 CDT 2010
 Run the "maint/updatefiles" script which will create the configure script and other files required to compile MPICH2 (Or you could take the nightly snapshots that already have the files generated for you - http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/nightly/).
Jayesh
----- Original Message -----
Cc: feiyunw at 163.com
Sent: Friday, July 2, 2010 11:41:45 AM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] [MSYS] fail to generate configure and makefile
I checked out mpich2 SVN trunk to c:\prj\mpich2 (rev.6844), and it comes without the configure script.
I tried to build it on MSYS/MinGW/WindowsXP but failed:
[quote]
$ cd /c/prj/mpich2/
jiehua at jiehua-PC /c/prj/mpich2
$ autoreconf
configure.in:736: error: possibly undefined macro: AC_MSG_WARN
      If this token and others are legitimate, please use m4_pattern_allow.
      See the Autoconf documentation.
configure.in:995: error: possibly undefined macro: AC_ERROR
configure.in:2504: error: possibly undefined macro: AC_CXX_EXCEPTIONS
configure.in:2505: error: possibly undefined macro: AC_CXX_BOOL
configure.in:2506: error: possibly undefined macro: AC_CXX_NAMESPACES
configure.in:2523: error: possibly undefined macro: AC_CXX_NAMESPACE_STD
autoreconf: /usr/bin/autoconf-2.65 failed with exit status: 1
[/quote]
Then I downloaded mpich2-1.3a2.tar.gz, and the configure script in it can work under MSYS, but it failed to generate the Makefile at last. See the attached log file for details.
I have two questions:
1. What are the commands used to generate the configure script?
2. Why it failed to generate the Makefile on MSYS? Did I miss something? Or it simply does not support MSYS/MinGW?
Best regards,
Feiyun Wang
mpich-discuss mailing list
