[mpich-discuss] X11 and mpich2 - passing environment variables with a colon in the name
John Watts john_watts at isoparix.com
Fri Jan 29 15:56:17 CST 2010
One of the parallel processes delivers graphical output to an X11
display.    By default ,when it runs under mpich2, it picks up a DISPLAY
value of NULL.    If I specify '-env DISPLAY 0.0', sure enough it tries
to open display '0.0'.    It fails, of course, because X11 DISPLAY
variables contain a colon (eg :0.0).
So here is the catch:   Colon is a special field-separating character in
mpiexec argument lists and I cannot figure out how to escape it or to
pass it across as part of an environment name.    The standard syntax -
and the resulting error - are::
 >mpiexec -env DISPLAY :0.0 -n4 executable_name
Error: no environment variable after -env option
Unable to parse the mpiexec command arguments.
What's the way around this, please?
John Watts
