[mpich-discuss] static compiling with mpich2
Jason Palmer
jason at sccn.ucsd.edu
Fri Jan 29 15:03:12 CST 2010
Hi all,
We recently switched from Mpich1 to Mpich2 as part of a general upgrade, and
I'm re-building a program that was previously compiled as a static binary
under Mpich1 on 64-bit RedHat Linux using pathscale fortran on an AMD
Opteron cluster.
We are now using gcc-4.4.3 (instead of pathscale), and I can compile and run
the code with dynamic libraries, but when I compile with -static, the
compile succeeds, but the binary gives a segmentation fault when executed,
with or without mpiexec.
I have tried compiling Mpich2 (using gcc 4.4.3) both with
-enable-sharedlibs=gcc and without, but both give the error in the static
version but no error in the non-static version.
Has anyone had success with static compiling of Mpich2 / gcc programs?
Jason
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100129/1b0b07a6/attachment.htm>
