[mpich-discuss] FW: MPICH1.2.1 Install Problem on Linux Redhat Enterprise 4 64 bit
Woods, Andrew Andrew.Woods at ATK.COM
Fri Jan 29 09:31:39 CST 2010
I have now subscribed.
Andy Woods
Sent: Friday, January 29, 2010 10:08 AM
Subject: MPICH1.2.1 Install Problem on Linux Redhat Enterprise 4 64 bit
Dear Mpich helpers:
I am attempting to install MPICH1.2.1 on Linux Redhat Enterprise 4 64
bit and the following error occurs after make VERBOSE=1 |tee m.txt:
-DHAVE_CONFIG_H -I.
-I/home/magic/mpich2_install/mpich2-1.2.1/src/mpi/coll -I../../include
-I/home/magic/mpich2_install/mpich2-1.2.1/src/include
-I/home/magic/mpich2_install/mpich2-1.2.1/src/mpi/datatype -O2
-I/home/magic/mpich2_install/mpich2-1.2.1/src/openpa/src
-I/tmp/bldmpich/src/openpa/src -DUSE_PROCESS_LOCKS
-I/tmp/bldmpich/src/mpid/ch3/include
-I/home/magic/mpich2_install/mpich2-1.2.1/src/mpid/ch3/include
-I/tmp/bldmpich/src/mpid/common/datatype
-I/home/magic/mpich2_install/mpich2-1.2.1/src/mpid/common/datatype
-I/tmp/bldmpich/src/mpid/common/locks
-I/home/magic/mpich2_install/mpich2-1.2.1/src/mpid/common/locks
-I/tmp/bldmpich/src/mpid/ch3/channels/nemesis/include
-I/home/magic/mpich2_install/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/
include -I/tmp/bldmpich/src/mpid/ch3/channels/nemesis/nemesis/include
nemesis/include
-I/tmp/bldmpich/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor
nemesis/utils/monitor -I/tmp/bldmpich/src/mpid/common/locks
-I/tmp/bldmpich/src/util/wrappers
-I/home/magic/mpich2_install/mpich2-1.2.1/src/util/wrappers -c
/home/magic/mpich2_install/mpich2-1.2.1/src/mpi/coll/opsum.c
/home/magic/mpich2_install/mpich2-1.2.1/src/mpi/coll/opsum.c: In
function `MPIR_SUM':
/home/magic/mpich2_install/mpich2-1.2.1/src/mpi/coll/opsum.c:57: error:
duplicate case value
previously used here
function `MPIR_SUM_check_dtype':
/home/magic/mpich2_install/mpich2-1.2.1/src/mpi/coll/opsum.c:92: error:
make[3]: *** [opsum.o] Error 1
make[3]: Leaving directory `/tmp/bldmpich/src/mpi/coll'
make[2]: *** [all-redirect] Error 2
make[2]: Leaving directory `/tmp/bldmpich/src/mpi'
make[1]: *** [all-redirect] Error 2
make[1]: Leaving directory `/tmp/bldmpich/src'
make: *** [all-redirect] Error 2
[root at VA90S-OPTERON-LINUX bldmpich]# pwd
/tmp/bldmpich
[root at VA90S-OPTERON-LINUX bldmpich]# make VERBOSE=1 |tee m.txt
Build steps were:
tar xfz /home/magic/mpich2_install/mpich2-1.2.1.tar.tar
/home/magic/mpich2_install/mpich2-1.2.1/configure
-prefix=/usr/local/mpich2/ |tee c.txt
make | tee m.txt
make install | tee mi.txt
in build directory:
/tmp/bldmpich
Can you please advise on this?
Andrew J. Woods
Sr. Scientist/Engineer
MAGIC Tool Suite Development Team
http://www.magictoolsuite.com
Alliant Techsystems (ATK)
8560 Cinderbed Road, Suite 700
Newington, VA, USA 22122
(703) 254 2416
Fax: (703) 339 6953
(Andrew.Woods at atk.com)
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100129/af21b472/attachment.htm>
