[mpich-discuss] mpiexec Execution Problem - No file or directory
    Brooks Garrison
    bgarisn at gmail.com
    Mon Jan 25 15:26:19 CST 2010
Hello all,
I currently have a 'cluster' of computers running Ubuntu 9.10.  I've
installed MPICH2 on all of them and set up each of the computers so
that all can ssh / scp to on another without requiring a password.
I'm able to start up my MPI daemons with
mpdboot -n 6 -f /home/bgarrison/MPI/mpd.hosts -v
I'm able to run
mpdtrace -l | sort  --> see the correct node numbers and their
corresponding IP addresses.
mpiexec -n 6 hostname --> see the correctly output names of each of
the nodes in my cluster.
mpiexec -n 6 /home/bgarrison/MPI_Build/examples/cpi --> see which
process is running on which node, the approximation of pi, the error
and the wall clock time.
I then tried to compile and run the following program:
#include <stdio.h>
#include <mpi.h>
main(int argc, char **argv)
   int node;
   MPI_Init(&argc,&argv);
   MPI_Comm_rank(MPI_COMM_WORLD, &node);
   printf("Hello World from Node %d\n",node);
   MPI_Finalize();
by CDing into the directory with the executable and running:
mpiexec -n 2 /home/bgarrison/bin/mpi_hello
but I get an error:
problem with execution of /home/bgarrison/bin/mpi_hello on Node1:
[Errno 2] No such file or directory.
BUT...if I copy the executable to the /home/bgarrison/bin directory on
Node 1, everything works fine.  I don't understand this.  I thought
MPI did the copy for you?
Is there a special directory I should put my executables in, in order
to run them on my MPI ring?
Thanks for any and all help.
Brooks
